Old 02-26-2007, 08:48 PM   #1
skokie
skokie's Avatar
Well I should have known
That pulling my 350 out of the 68 would lead to many other issues
The whole thing started out with puling the motor, putting on a new flex plate, and a new oil pan gasket. Well once we got the pan off and saw that the gasket was shredded pretty good (explains that oil leak from the back which I thought was a rear main seal) we decided that we should pull the rear main cap and have a look at its seal.
Yup bad. Now I didnt have a engine stand just a rented cherry picker. So knock knock on the neighbors door. In luck. He has one he is not using and is in no rush to get it back. Onto the stand it goes and turn it over. After pulling all of the caps and inspecting them we see a very small amount of scoring. Btw the we is my brother n law who raced pro gas for 20 years and knows his way around a small block.
He said that he didnt see any loose metal (we looked again anyway) and thinks it was dirt due to some of the dirt we saw around it. So after changing out the seal we buttoned it up and in steps torqued it down to the right amount. Then I put the pan on and broke the head off of one of the bolts. But I got lucky there. I pulled the pan again and there was a big enough piece to grab it with a pair of pliers. Out it came. New bolt.
In short the engine is still on a stand awaiting its new flex plate and a good cleaning. I didnt come this far to not clean the dirty bastage And now for the question. How am I going to torque the flexplate down on a engine stand?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-26-2007, 09:06 PM   #2
PumiceMan
Junior Member
PumiceMan's Avatar
Re: Well I should have known
My engine stand doesn't give me any room to install a flexplate, so I end up picking the block back up with the hoist and taking the engine off the stand. If you lower the engine down to make contact with the floor, but not let it support much of it's own weight, you can torque the flexplate bolts without too much problem. If you don't want to scratch the pan bottom, put some cardboard or something down first.
69 GMC Sierra 1500 Custom
68 Camaro SS
18 GMC Sierra SLT
Living the dream
PumiceMan is offline   Reply With Quote
Old 02-26-2007, 09:11 PM   #3
1969k10stepside
I sometimes rest my motors down on a tire
1969k10stepside is offline   Reply With Quote
Old 02-26-2007, 09:21 PM   #4
rage'nrat638
rage'nrat638's Avatar
i installed mine when i was putting it back in
i love taking pictures
rage'nrat638 is offline   Reply With Quote
Old 02-26-2007, 10:17 PM   #5
skokie
skokie's Avatar
How did you do that Mark? Whats your secret?
68 build thread
Old 02-26-2007, 10:25 PM   #6
rage'nrat638
Talking Re: Well I should have known
the lifting plate.. install that on the intake lift the engine up. remove the engine stand head and install the flex plate with it hanging there install your like new engine
Old 02-26-2007, 10:28 PM   #7
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Mark,I think he meant how you kept it from turning when applying torque the bolts??? Can you use a piece of wood though the hole on the flex plate?
Dean
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-26-2007, 10:33 PM   #8
rage'nrat638
this is how i set up my engine stand head..
i can remove and install the flex plate at will..from underneath
i have installed the starter with the flex plate and turned the engine over using a battery before. on the stand.
i will most likley start the 400 on a home made stand in the garage.. you can bet i will have pictures
Old 02-26-2007, 10:36 PM   #9
Sport/Truck
Sierra Grande Club
We want videos!!!
Old 02-26-2007, 10:39 PM   #10
rage'nrat638
Originally Posted by Sport/Truck View Post
We want videos!!!
coming this summer to all 67-72 chevy truck board viewers
Old 02-26-2007, 10:42 PM   #11
Sport/Truck
Sierra Grande Club
(Hands rubbing together in anticipation) I can't wait!!!
Dean
Old 02-26-2007, 10:31 PM   #12
1969k10stepside
Use a impact wrench,it wont turn till it gets real tight
Old 02-26-2007, 10:33 PM   #13
Sport/Truck
Sierra Grande Club
3/8 or 1/2in drive.
Old 02-26-2007, 10:34 PM   #14
1969k10stepside
I use 1/2",my 3/8s dont work to good I just gotta make sure they dont get to tight and over tighten them
Old 02-26-2007, 10:49 PM   #15
skokie
skokie's Avatar
Mark
Did you just give a shot of threadlocker in each hole? Or did you coat the threads on the bolt?
68 build thread
Old 02-26-2007, 11:07 PM   #16
rage'nrat638
i cleaned the bolts with brake cleaner to remove the oil and put it on the threads and torqued to specs. with the impact
Old 02-26-2007, 11:26 PM   #17
skokie
skokie's Avatar
My next door neighbor has a impact. Maybe he has a 100ft cord I can run across to my house
68 build thread
Old 02-26-2007, 11:55 PM   #18
1969k10stepside
Keep in mind that pressure will be lost with that long cord so you wont have as much pressure as if it was connected to a cord not as long.
