Sb 400 club
Anyone running these head lights??
IS anyone running these or have an oppion aboput them?? Myu stockers are horrible and I am wanting to upgrade.
thanks http://cgi.ebay.com/ebaymotors/82-87...QQcmdZViewItem
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
The One And Only !!!
Re: Anyone running these head lights??
I bought the same ones but round for mine but there still in my storage room waiting. I plan on wiring from the switch to relays to get FULL battery voltage to them instead of powering through the harness and headlight switch.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
i was looking at a set of the crystal clear lights in the lmc cataloug. they should be alot better than the stock ones also
K5Camper
![]() Join Date: Mar 2004
As Restorob stated, moving to the H4 conversion bulbs is a good step, but you won't yield that much better lighting until you add the relays in. Do a search on Headlight relays and you will come up with a ton of info.
I wouldn't make the switch to the bulbs without it.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
Sb 400 club
ahh yes i know about the relays that are needed and that it is a good idea to upgrade the harness as well, but is anny one running these on a truck or similar? I am looking for 81 plus truks with the square lights. Thanks again for all the help and input
