Not a bad nut after all..
Tach Sticks
I have a Camaro tach in my truck. It sticks at 2200rpm. The only way to get it unstuck is to drive over some bumps. Any ideas why it sticks?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
Worthless
Re: Tach Sticks
TTT for you, I'm having the same problem with 2 of these!!
DODGE SMACKDOWN CLUB
Re: Tach Sticks
buy a better tach
George Bush hates midgets |
68 C10 Longbed
Re: Tach Sticks
What's up with that. I also bought a restoration tach for my 72 Z28 and it idles perfect up to 2400 RPM and then stops like its stuck! Does anybody have one that registers above 3000??
Re: Tach Sticks
The factory one in my 1980 Camaro works perfectly.
Re: Tach Sticks
Not all that familiar with the camero tachs but --the original truck tachs are not the greatest in accuracy or design. Sometimes some of the foam tape used to edge the protective cardboard circular cover comes loose and gets inbetween the magnets and the armature causing a bind. Common problem. You would need to carefully disassemble the thing to check for junk in there. I have found foam, dust, dirt, dead bugs, etc stuck in them from time to time. Good luck--Huck
#7 | |
Re: Tach Sticks
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Re: Tach Sticks
WTB this ad
Re: Tach Sticks
