Old 03-01-2007, 10:36 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Changing leafs to 4 link?
I have a 72 GMC long bed with rear leafs. I think I have decided on on installing a 4 link ARS14500. I do need to install a C notch kit, right? Anyone installed a 4 link in our trucks. I know that the guys at ART are knowledgeable, as well.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-01-2007, 11:32 PM   #2
jlaird
jlaird's Avatar
Re: Changing leafs to 4 link?
that kit really isn't made for your truck. What i'm trying to say is it isn't going to just weld-on without modification because the rear framerails are not straight on the 67-72.
If your willing to fab up additional bracketry to get the front mounts of the 4-link to attach to the framerails, then it will work just fine. Also, depending on how low you want to go, your going to want a least a c-notch with this setup.
jlaird is offline   Reply With Quote
Old 03-07-2007, 12:51 AM   #3
70short/step
70short/step's Avatar
here is a link to see what was done on my short step. If you wanna drop it low at least a C-notch is needed. You can also see that with the ART 4 link how we spaced out the fron of the 4 link because our frames are wider at the axle and narrower going forward.
http://67-72chevytrucks.com/vboard/s...d.php?t=179176
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 03-08-2007, 10:22 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Oh, well screw that then!! I'm not into extensive steel fab work. Maybe I will just convert my truck over to trailing arm bars. Anyone have some decent ones for sale?
Old 03-08-2007, 10:59 PM   #5
SCOTI
SCOTI's Avatar
Instead of getting ART's 4-link kit you could get their 60-72 Trailing Arm Kit. It should have everything you need to change your truck over to the trailing arm suspension.
Of course it would be cheaper to get a set-up from someones junked project . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2007, 11:04 PM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I just checked ART site and could not find their 60-72 trailing arm kit.
Old 03-09-2007, 01:04 AM   #7
SCOTI
SCOTI's Avatar
Go to their web site & under the 'New Products' icon look for this: New!!! 63-72 GM C-10 Trailing Arm & Crossmember StrongArm Kit
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-10-2007, 11:07 AM   #8
blazer2007
do they make a trailing arm setup for 78 blazers?
blazer2007 is offline   Reply With Quote
Old 03-10-2007, 12:28 PM   #9
SCOTI
SCOTI's Avatar
Not a 'bolt-in' kit. HotRodstoHell makes a 'universal' kit that could prob be adapted to work.
For the cost & the amount of work it would take to adapt it to your 78 Blazer, you might be better off getting an aftermarket trailing-arm crossmember (ECE, ART, CCP, or stock GM) since they're 33" wide which is just the right width to slip inside your frame rails (dbl check the measurement under your floorpan roughly where the pass's feet would hit the floor)..... meaning it could be bolted-in after drilling the necessary holes in the frame rails.
Then pick-up some used arms from a board member, get the correct 'pads' to locate the arms to the rear-end housing (also available from ECE, CPP, stock car products). Another alternative is a complete rear-end out of a 67-72. The 67-70 rears would be slightly narrower (1.5"); 71-72 about the same. Make your own reinforcement area where the springs will mount (box the frame) & run a crossmember (it could be a piece of sq/round tubing) for shock mounts. Get a Super Track-Bar' kit from ECE for keeping it all centered.
The HR2H kit would be more adjustable if you have the $$. If not, you could piece everything together on a smaller budget & have the adjustability that came factory engineered from GM on 60-72 trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-10-2007, 06:02 PM   #10
mullit
mullit's Avatar
web address for hotrods to hell?
mullit is offline   Reply With Quote
Old 03-10-2007, 10:06 PM   #11
SCOTI
SCOTI's Avatar
http://www.hotrodstohell.net/index.htm
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
