Old 03-12-2007, 02:58 PM   #1
jorgensensc
jorgensensc's Avatar
Quick Engine Timing Question!!
350 engine. #1 piston at tdc (right side looking at engine. rotor on #1 plug, but which rocker is up, first or second? Trying to get it back in time before the install since I had the dizzy out and installed pulleys and think I turned the engine a couple of times. Thanks in advance!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
