Old 03-23-2007, 06:04 AM   #1
D13
D13's Avatar
Help- which truck indecision!
in the market for a driver, 70+ Michigan miles a day 5 days a week, 3 miles dirt 20 miles highway 10 miles city rest country. Really like 81-87 GMC and Chevy full size. looking for reasonable fuel mileage and long life, and not a 4wd. Already hav a 99 NBS tow beast so that's not really an issue. Found several possibilities and would like input.
84 1/2 ton 250 6cyl THM350 100k probably 3.08 or 3.23 10 bolt so could put 2.73 in it. Beleive this would get 17mpg or so as sitting, would look at swapping in 2004R and getting close to 20mpg. $3k + trans
84 1/2 ton 6.2 diesel auto 100k would this get 18mpg? $5k Anyone know what trans and rear end and ratio it is likely to have?
87 3/4 ton 5.0 probably a 700R4 60k I would bet 15-16 mpg probably 3.43 14-bolt so not much more highway gear available $5k
All have decent to great bodies and interiors. I'm assuming that the tires etc are in eqivalent shape and that I have to add a posi to whatever I get. I'm very familiar with the 6cyl, SBC are common and I know nothing about diesels.
All opinions welcome!
D13 is offline   Reply With Quote
Old 03-23-2007, 07:01 AM   #2
Blackstone
Blackstone's Avatar
Re: Help- which truck indecision!
I think the six-banger is called for in this situation. Considering the extra cost of diesel fuel, there isn't much to gain there.
Blackstone is offline   Reply With Quote
Old 03-23-2007, 07:35 AM   #3
rcbildr
rcbildr's Avatar
I think the diesel should get better than 18mpg, my 2wd diesel burb got at least 22mpg. My 4x4 diesel burb gets 19mpg. My guess is the truck has a 700R4. Not sure about the rear gears, of the 3 diesel rigs I have in my yard the 2 Suburbans have 4.10's and the 83 4x4 shortbed has 3.73.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 03-23-2007, 07:45 AM   #4
grinch4om
dang its hot
grinch4om's Avatar
my vote for the six
grinch4om is offline   Reply With Quote
Old 03-23-2007, 09:23 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
id vote for the six myself a company i worked for had two FOrd vans the exact same E250 trucks one being diesel and one being the v8 gas and they got the same exact mileage
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-23-2007, 09:34 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Since MPG seems to be an issue, I would buy the diesel or wait until you can find an '87. They are fuel injected, and have overdrive transmissions available.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-23-2007, 01:27 PM   #7
D13
D13's Avatar
The 87 is FI but 5.0. I need to find out if the 84 6.2 has O/D. They did not offer L6 with FI in the US, went 4.3 instead, would happily buy one except everyone seems to have replaced them with carb 5.7.
Old 03-24-2007, 02:41 AM   #8
rcbildr
rcbildr's Avatar
Neither of the 2 diesels I have driven had O/D...the 2wd had a TH-400 and I converted my 4x4 to an SM-465. The shorty actually belongs to a good friend of mine, and shortly after I got it running (had to replace the engine) the tranny (700R4) went out on it.
My Projects:
1978 Camaro Z28
Old 03-24-2007, 11:37 AM   #9
74 shortbed 406
In my experience the six will drink just as much as a 350. I had a 74 with 350 turbo and 3.73 rear gears. The six got 10-13 depending on how hard you pushed it and the 350(stock rebuild) got 13-14 and it was more consistent on mileage. As for the 87, I have one now with tbi 350, 4x4, 465 tranny, and 3.08 gears and it is at 14-15.
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 03-24-2007, 11:59 AM   #10
dswancutt
The 250 sixes with intergral heads also have tendency to crack heads. That is what happened to my 79 with a six. I never got really good gas mileage with it, but the motor was shot. I would go with the 87 5.0. I have a 78 k-10 with a 5.0 running 3.73 gears and could get 13 mpg, and that was with a wore out carb.
dswancutt is offline   Reply With Quote
Old 03-24-2007, 02:19 PM   #11
Pyrotechnic
Pyrotechnic's Avatar
A 305 with 2.73's and a Turbo 350, or a 305 with 3.08's and a 700R4 are good combos for getting really great gas mileage. Possibly into the 20MPG range. The 700R4 will be the best bet since it's got a lower first gear to make take off easier, and it's got the lockup clutch which will help out a lot too. I would go for the 305.
Pyrotechnic is offline   Reply With Quote
Old 03-24-2007, 02:57 PM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I vote for the 5.0 motored truck.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-25-2007, 11:31 PM   #13
Duro5341
Duro5341's Avatar
Personally I would go with the diesel, being your concerned about MPG, and long lasting.....you won't beat a diesel in these catagories
I would guess the diesel would have a TH400, and a 14 bolt rear end....with the massive amount of torque the diesel will put out...these would hold it quite well.
Also the diesel will be better if you ever decide to pull anything....you will have no problems
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 03-27-2007, 05:59 AM   #14
D13
D13's Avatar
Neat, the opinions split just like my brain!
I'm a little leery of the 6.2, they very sensitive to being properly maintained.
Maybe I'll see if I can buy the FI 305 truck and when I wear out the motor swap in my spare 250. And I already have a non-integral head for it (BTDT).
Many thanks for the input, a lot of good material for my poor brain to chew over.
Old 03-27-2007, 06:01 AM   #15
D13
D13's Avatar
Yep, but it's a 3/4 so probably 14 bolt w/3.43 gears. Looking at 15-16mpg probably. But the truck is NICE.
