Old 02-28-2007, 09:21 AM   #1
BAD4X4
BAD4X4's Avatar
1972 8"lift I got questions?????
Well I have done about 100 lift kits on 67-72's, but they all have been 6"or smaller.So I have a 1972 k-20 right now with a 6" lift and I want to put a 8" in it. I was going to put front springs in it and do the 2"block in the back since it has springs in the rear, and longer shocks and drop pitman arm. I was wondering if drivelines would have any problems? I know I'm probably going to have to lengthnd the front driveline. I'm going to run 37x13.50x17 toyo mt's on it. Thanx for the help Dana
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 02-28-2007, 04:40 PM   #2
Re: 1972 8"lift I got questions?????
I`m watching for answers here,too.I`m the same way with 6" being the most I`ve done.My concern is in the front d-shaft u-joint angles.I always figured I`d do a CV @ the axle end.The dbl cardon should be good.May require some clearancing.
Old 02-28-2007, 05:35 PM   #3
customcamper72
ask vtblazer, he runs a 8" lift, i believe. or look in the thread asking about 38
inch tires.
customcamper72 is offline   Reply With Quote
Old 02-28-2007, 06:53 PM   #4
Yeah,but that`s a Blazer with coupled t-cases.Won`t be apples to apples.He did do custom d-shafts,so can give good info on that.He`ll prolly see this here.
Old 02-28-2007, 08:03 PM   #5
OBD60
I have a 70 k10 shortbox I purchased with a 6" lift. Bad steering and brakes included. Everything was stock other than the springs. Now it has a 10" suspension lift, that is about as high as you can go without cutting and turning. Alcan 8 1/2" springs with custom shackles for the other 1 1/2" on the Dana 60 front. Tough Country 6" springs with 4" block (shackle flip to come) on 14 bolt rear. High Angle driveline front and rear, yokes flanges etc. Four wheel disks and crossover steering with a block on the knuckle is a must to run the bigger tires. Doesn't bind at full droop but is close on the front. If you can go high pinion, so much the better. While you're at it might as well get O.R.D.'s fush and rear shackle and all greasable bushings. Not cheap but a good set up.
OBD60 is offline   Reply With Quote
Old 02-28-2007, 08:42 PM   #6
1969K10
1969K10's Avatar
I'm guessing you could index the X-fer if you run into driveshaft angle problems.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 03-01-2007, 04:19 AM   #7
GMC71k20
hey guys,
i got 8" skyjacker all leaf on my 71 ke2500. its been a couple years since i put the lift on but ill write what i remember and ill be home from college this weekend so if you need any pic's or measurements let me know.
-front driveshaft will need to be lengthened
-never had a problem with stock rear driveshaft
-if you got extended brake lines from the 6" lift they should still be fine because i think the brake line kit i got was for 6-8" lifts
-needed to use a drop pitman arm and raised steering arm and i can barely make a left turn. if i want to do a left u-turn, i need 3 lanes, soon as i get a real job im getting cross over steering
any other questions let me know. i usually check this board daily
GMC71k20 is offline   Reply With Quote
Old 03-01-2007, 08:08 AM   #8
Did you re-center your steering after the lift?
Old 03-02-2007, 12:46 AM   #9
GMC71k20
nope...never found any info on this online even when i searched pirate4x4, if you can help me fix this ill prob pee my pants in happiness
Old 03-02-2007, 10:22 PM   #10
earl87gta
earl87gta's Avatar
GMC71k20
thats a sweet GMC what size tires are you using.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-03-2007, 12:30 AM   #11
bigtruck81
you need to lengthen your drag link.
bigtruck81 is offline   Reply With Quote
Old 03-03-2007, 09:04 AM   #12
Kinda hard to explain.What Bigtruck81 said,basically.
Get the wheels straight
Turn to the right counting the turns of the steering wheel
Turn left,same thing and figure the difference...like 2 to the right/3 1/2 to the left
Get wheels straight again
You need to take 3/4 turn out from the let to give 3/4 to the right
Pop one end of the drag-link
turn steering wheel the 3/4 to make centered
Adjust drag-link till it fits in it`s hole
Old 03-03-2007, 12:31 PM   #13
GMC71k20
thanks so much for the help,i cant wait to get the truck out of storage to fix this, all the local guys said its just what happens from too much lift.
earl, its got 35" all terrains for now, i got all 4 used for $100 bucks cause my friends 70 GMC went down to stock height. When i get out of school in 08 the truck will finally get the big block in and some 38"s
Old 03-03-2007, 10:01 PM   #14
I still have to center my Highlander.I got it all done,then winter hit and I haven`t gotten to it.So,don`t feel bad.I hope you could follow that.
Old 03-03-2007, 11:12 PM   #15
BAD4X4
BAD4X4's Avatar
My buddy is at the comp show in seattle, and called me and told me he orderd my 8"front springs and got a great deal on them. I know what I'm doing next weekend. I will post pics when finished. Thanx Dana
Old 03-03-2007, 11:33 PM   #16
earl87gta
earl87gta's Avatar
they look bigger then 35s I have 36 on mine know and it doesnt look that big.
Earl
Old 03-04-2007, 12:40 PM   #17
Sounds awesome,Dana.Keep us posted.What`s up with the shortbed 4wd?
Old 03-04-2007, 01:37 PM   #18
BAD4X4
BAD4X4's Avatar
Its all done but, waiting for chrome button head allens I had to special order for the rear diff cover, and align it. I had to cancel align appointment weather been to bad over here, So I'm gonna do it myself. Till I can take it down this summer. Ya know it suck's to live on a dirt mud hole road. The wife was thinking we could have a mud boggs out front of our house and charge money!!!!!
Old 03-04-2007, 03:52 PM   #19
I know.I used to.And,even though I`m into 4wds,it`s nice to keep them clean while you`re not playin`in the mud.I have a stone driveway but I`m by the road and that`s paved.
Before I met my wife I lived on a dairy farm in the old place way off the road.You had to open and close the gate by the road,cone down along the creek on the rocky lane,watch for cow pies(14.50s love to fling it),cross the creek,up the hill with a good run up to the house because that was just pasture.You`d park and the house had a fence around it to keep the cows out.They were always lickin`my mirrors and paint.I had an aluminum cap down by the out buildings and the cows knocked it over and walked all over it laying upside-down.My girlfriend drove a`76 4spd Vette w/sidepipes and she`d take forever coming down thw lane.I could take a shower and be dressed from the time I first heard her,til she got there.I like living out away from things,but look at that before I decide to move.
When do we get to see the truck?And,which one gets 8"s?
Old 03-04-2007, 04:33 PM   #20
Kurt L
Kurt L's Avatar
i bought a 8'' lift from skyjacker a few yrs ago.it came with everything that you needed to lift it.the only thing i had to buy diff was the stainless steel brake line's,the ones fort the front were 20.00 a piece then the one for the back was 90.00.but kit came with springs u bolts shocks steering arm[raised]i used my blocks in the back that were already there.i had bout 1200.00 in total lift.but that was back in the 80's.it was called the soft ride lift.
Kurt L is offline   Reply With Quote
Old 03-04-2007, 06:19 PM   #21
BAD4X4
BAD4X4's Avatar
My 1972 workhorse work daily driver is getting the 8's. I will get pics of the show truck and the 8"lift one probably next weekend...
Old 03-05-2007, 12:11 AM   #22
Cool,can`t wait.
Old 03-05-2007, 12:13 AM   #23
1969k10stepside
Me too...
1969k10stepside is offline   Reply With Quote
Old 03-14-2007, 09:41 PM   #24
72cheyennesuper20
72cheyennesuper20's Avatar
Did you take any pics yet? I would love to see it.
72cheyennesuper20 is offline   Reply With Quote
Old 03-14-2007, 11:54 PM   #25
BAD4X4
BAD4X4's Avatar
Just got in, from getting it almost done. I'm still waiting on the pitman arm and draglink. Going and getting the new blazer this weekend took up all my time. I will put the 37's on saturday and post pics. Thanxc Dana
