Sfbd ??
Anyone have pics of how they did their stock floor body drop. I am installing Porterbuilt's Dropmember, and will be doing the rear when I get done. I want to lay the body on the ground. Does anyone have custom body mounts. I much will I have to lower the mounts?
Brad |
belly dragger
Re: Sfbd ??
Is this a truck or a Blazer?
SAVE THE PLANET DRIVE AN OLD TRUCK |
Re: Sfbd ??
It is a 69 short wheel base. I will be running 22's all around.
Active Member
Re: Sfbd ??
I lowered my cab mounts 1.25" and it is more than enough to lay body...
Re: Sfbd ??
Ok man, How did you lower them and remount them? What did you do to make sure everything lined up and was exact? Thanks
Active Member
Re: Sfbd ??
drilled out the rivets, cut the bottoms off them so they wouldnt hang lower than the frame, then measured a million times and welded them back on...
Sold! 2 days after finished
Re: Sfbd ??
Watch running thoes 22s and trying to go retarded low in the front. Youll be getting a million dollar set of custom offset wheels or making a custom hood like CAMAROTHUNDER. My 20s almost come to the top of the fenders.
Re: Sfbd ??
Well I will be running a 67 front end. I will have the dropmember. Wont the dropmember narrow the front enough to lay it all the way down and not hit the fenders?
![]() Join Date: Feb 2006
Re: Sfbd ??
man, laying body w/22's sounds almost impossible, but im sure it can be done
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
#10 | |
Re: Sfbd ??
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Re: Sfbd ??
if customs did it
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com Last edited by N2TRUX; 03-28-2007 at 11:52 PM. Reason: Keep the pics family friendly please. |
Insert Title Here
Re: Sfbd ??
laying body on 22's
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Señor Member
Re: Sfbd ??
Will be looking for pics of this
Re: Sfbd ??
WOW,
That truck is yellow... |
#15 |
Re: Sfbd ??
That yellow truck looks like it is running the stock hood? Does anyone have any pics of these trucks aired out with 22's? I just want to know what it will look like and how much lowered the body would need to go!!
#16 |
Insert Title Here
Re: Sfbd ??
im pretty sure it is aired out in those pics, its on the ground
#17 |
Outlandish Trends - FL
Re: Sfbd ??
![]() ![]() ![]() Look how far back the centerline of the front wheel is from the center of the wheelwell. That just looks kind of goofy to me.
-Bret 67 short-fleet sold! |
#18 |
A guy with a truck
Re: Sfbd ??
Are you doing something to remedy this on your truck? I think you may end up with the same affliction...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#19 |
LAIDOUT
Re: Sfbd ??
I don't see any tail lights... what do they drop out from under the pan when its airred up? ha ha...
#20 |
Epoxy Primer Friendly
Re: Sfbd ??
Laying door with a 235/60/15
![]() Laying door with 265/35/22's ![]() My hood mods. not complete yet. ![]() GOOD LUCK ! ![]() Last edited by camaro__thunder; 04-01-2007 at 02:34 PM. |
#21 |
Re: Sfbd ??
ya but I dont want to go all the way to the doors. I just want to lay rockers! I might even set it up to have the rockers about a 1/2" off the ground, just so I wont have to worry about trashing the paint.
#22 |
Re: Sfbd ??
Here's some pics of the truck before we do the 'stock floor body drop'... (never really made much sense to me for somebody to call it that, by the time you're done tunneling for the trans and driveshaft it's not much of a stock floor anymore!).
The tires are 265 35 22's, they are currently into the hood (see pic) where the upper and lower skins are pinch welded and form an edge... before the body drop. We will be lowering the mounts and doing a custom hood treatment (like what IF custom's has done) to give the tires clearance at the hood. I will be starting a build thread on the whole truck in the near future, and will reference the link in this thread as well.
#23 | |
Señor Member
Re: Sfbd ??
#24 |
Re: Sfbd ??
You have special powers when you're a super fabricator
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
#25 | |
Re: Sfbd ??
