Old 04-28-2007, 12:03 AM   #1
randomhero472
randomhero472's Avatar
Questions for the DIY wood bed guys!!!!
I've got a couple questions for you guys out there that have done your own wood beds.. I went to lowes today and looked @ pine and oak, i actully like the pine better as far as the color and grain, so heres my questions: what type of stain did you guys use, i looked at stain for indoors and also some stains for decks-outdoors: which would be better, also looked at some outdoor varnish/clear, some of which has SPF 25 ratings, is this somthing i should look into, anything that will help me out would be fantastic, any finishing techniques, tips-tricks would be greatly appreciated!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 04-28-2007, 02:01 AM   #2
Down south truckin
Down south truckin's Avatar
Re: Questions for the DIY wood bed guys!!!!
you really need to find some air dried wood from a sawmill or hardwood supply company I've done a few and seen some of my friends that used kiln dried wood and they look great for a couple years but after that they start cracking, good luck with your project, DST
Down south truckin is offline   Reply With Quote
Old 04-28-2007, 08:23 AM   #3
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Pine really doesn't take a stain very well. We suggest you do some testing on small scrap boards before you do the bed boards. Be sure it will turn out like you wanted, especially if you use pine.
We have done testing on various finishes to see what lasts in the Oklahoma weather. http://www.mar-k.com/wood_finish_testing_ii.html The pine boards painted with POR 15 and black gloss enamel still look great after nearly two years continuous exposure to the weather. All other finishes tested have some degree of failure during the same time period.
Whatever you use, be sure to coat all surfaces, top, bottom, ends, inside drilled holes. Use something to seal and "prime" the wood first to get great adhesion, then coat it with your topcoat to provide good UV and moisture protection.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 04-28-2007, 10:05 AM   #4
cdowns
cdowns's Avatar
i too suggest geting wood from a specialty wood supplier as the homedepot lowes wood isnt a real good choice. for my woodworking projects i also allow a minimum of a year of storage to allow the wood to stabilize for a better finished product even better is old wood if you can find it
Old 04-28-2007, 10:29 AM   #5
randomhero472
im not going for a top show quality bed here, also should have said.. the truck will be stored indoors.. this thing will be of a toy than my DD. I'll check around here for any mill's-specialty shops.. keep the info coming
Old 04-28-2007, 01:40 PM   #6
slomotion
Old Duffer
slomotion's Avatar
Do a search here. There's been a couple of threads lately.
If you do decide to use pine, give it a coat of sealer after all the sanding, etc and then stain it if you like. The sealer will allow the stain to penetrate evenly and prevent the blotches that pine is known for.
Depending on the color of your truck, these are nice looking woods when finished;
Oak and Ash - light, Cherry - medium, Mahogany - dark.
If you go to a specialty store and find a wood you like, moisten a small corner of it to see what color it will be finished.
Good Luck!
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 04-28-2007, 04:53 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Also go look at Marine grade varnish and sealers.Everyone I have talked to says they will stand up better than any home use product.They are more expensive but still cheaper than redoing the bedwood again.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-30-2007, 02:20 PM   #8
ToddSS
It's not that expensive to do it right. I got my rails powdercoated so they look new and I put in white ash and did it right and it was only around $300 for everything. May as well do something that is going to last.
That lumber at the home Depot or whatever warps on the way home from the store, after you dig through all the warped and cracked stuff on the shelf in the store!
1968 C10 SWB
ToddSS is offline   Reply With Quote
