Old 05-18-2007, 07:38 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Tear down complete - rebuild begins
I finished the front end tear down this week. The suspension is completely off. Now the rebuild process begins. The suspension is getting rebuilt first. The new engine and tranmission will be put in after I bolt up the suspension and paint the entire front end.
I'll post pictures of the suspension rebuild on this photo album.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-18-2007, 08:12 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Tear down complete - rebuild begins
Pretty cool photo album, nice job on the front end. Also like the plastic and kitty litter brings the whole project to life.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-18-2007, 08:46 PM   #3
ocbaud
Garage Queen Material
what did you use to paint everything?
ocbaud is offline   Reply With Quote
Old 05-18-2007, 10:58 PM   #4
BaddBusa2005
BaddBusa2005's Avatar
it looks like por15, i love how glossy that stuff turns out. I am not usually one to like glossy but it looks good. Good job man
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 05-19-2007, 04:29 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Looks great. Have fun with the rebuild.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-19-2007, 10:11 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
This don't look good...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-20-2007, 05:03 PM   #7
gchemist
gchemist's Avatar
POR-15 was used on the a-arms. I had to reuse the original shafts. The shafts I prepared with the suburban arms won't work. The POR is too thick to slide the new bushing over. The picture above displays how I removed the original shafts. I drilled out the rubber bushing on both sides, then slid the shaft out.
So WARNING...use only POR15 on the inner portion of the shaft and nothing else. If you use POR15 on anything like threads or the anthing you need to press, you will have a hard time using the part again. The frame, fenders, firewall, and everything else will have Zero-Rust instead of POR15. ZeroRust is basically the same but it lasts longer.
I'll post a picture of the damaged a-arm. The a-arm was damaged going 70 MPH on some back road. The groves were very deep from semitrucks.
I taped plastic sheets on the concrete floor. The entire truck is sitting over plastic. The kitty litter has helped reduce the mess on the floor. The litter has collected oil, coolant, trasmission oil and even all the water from pressure washing. There is almost no runout of contaminates from the garage. Good thing because the street drain directly in front of my house has a no dumping sign. All the water goes into a pond on the backside of my neighborhood. You can catch small fish and see an occasional turtle.
Old 05-21-2007, 12:43 AM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
Nice job G-man but that Por15 looks like some messy sheet, what actually is that stuff, never used it
John
Malo83 is offline   Reply With Quote
Old 05-21-2007, 09:02 AM   #9
gchemist
gchemist's Avatar
John,
POR-15 is messy. I used a brush on the a-arms, parts, and transmission crossmember. If you use it, it's better to hang parts then coat them. You want any excess to run off.
I'm using ZeroRust in a paint gun. The stuff also comes in aerosol cans. The cans are easier to use in hard to reach places. Especially the door jams. I'll post pictures after I use ZeroRust on the fender wheels and fenders.
Old 05-21-2007, 11:43 AM   #10
chevysnbuicks
Where did you get that tranny crossmember?
Chevy makes a fine truck, but a really BAD airplane!
(haha, long story.)
chevysnbuicks is offline   Reply With Quote
Old 05-21-2007, 05:04 PM   #11
gchemist
gchemist's Avatar
The crossmember was made by a member of this board. A long time ago. My truck has the one bolt type trans mount. I had the crossmember drilled for two. The trans mount that comes with the front end kit is a polygraphite mount that can be used as a two or one bolt mount. I have yet to mount the brackets for the frame rails. I'm going to have to drill the bolt up brackets.
