Old 05-19-2007, 09:06 AM   #1
jamis
F.A.S.T. president
jamis's Avatar
who sells -7" rear springs
I have read mention of 7" drop coil springs for the rear but I can find which vender has them. Can anyone point me in the right direction?
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 05-19-2007, 11:20 AM   #2
BigTruckDriver
BigTruckDriver's Avatar
Re: who sells -7" rear springs
Thats a little extreme IMO. Can you get most of the drop with springs and the get some more with blocks?
BigTruckDriver is offline   Reply With Quote
Old 05-19-2007, 12:12 PM   #3
jamis
F.A.S.T. president
jamis's Avatar
It is, but I have a c-notch and already have -5" springs and 2 inch blocks. At seven inches I sill have too much rake with the tall MT tires I want to run. I don’t want to run bags because of the additional compressor and other accessories I would have to add.
Old 05-19-2007, 12:19 PM   #4
BigTruckDriver
Could you go to a bigger block, maybe 3 "? 7" drop is asking a lot from a spring If you happen to go to a bigger block be sure nothing (trailing arms,etc) go below the lower edge of the rim.
How tall is the MT? How low are you in the front? What year is the truck?
You could run bags with out all the accessories. Keep a portable air tank close by at all times though. Are you running the truck on the drag strip?
Old 05-19-2007, 12:38 PM   #5
jamis
F.A.S.T. president
jamis's Avatar
Truck is a 71 . I dont want to go 3 inches on the block, the u-bolt nuts are already below the 15" rim. The tires are 30" tall from what I can remember.
I can’t remember how low I'm in front but I don’t think I can run a taller tire to level it out some.
The rear tires I tried are not mine so I can always purchase a shorter tire for the rear. I just thought I read somewhere they make a 7" spring.
The truck will never haul anything and it will unlikely see weekly use.
I wonder if I can run bags without the unboard compressor since I wont have a neeed to lower and raise it on the fly.
Old 05-19-2007, 12:43 PM   #6
BigTruckDriver
I am sure a 7" spring can be found but IMO your ride quality will suffer. Could possibley even get some serious wheel hop. Unless you need the 30" for gearing on the drag strip (OR RULES) you could go to a smaller tire. Whats the diameter of your front tires?
Old 05-19-2007, 01:25 PM   #7
royo
royo's Avatar
all i could find was 6 in spring an 1.5 block or 2 in bl ece or gmc pauls
nickle and dime
royo is offline   Reply With Quote
Old 05-19-2007, 02:03 PM   #8
jamis
F.A.S.T. president
jamis's Avatar
I Think the fronts are 28 high, 3 inch springs and 2.5 spindles.
Why would a 7" spring ride any different from a 5" spring as long as it didn’t hit the bump stop or coil bind like from the guys that heat and collapse the springs? I think the springs are just made shorter not weaker.
I'm no suspension expert....any input is appreciated
I dont have a need to run that tall of a tire, I just like the way the big tire fills up the wheel well, kinda like Rosie O in spandex If I could I would even go up to a 32" tall a tire
thanks for looking, that’s all could find as well
Old 05-19-2007, 06:25 PM   #9
SCOTI
SCOTI's Avatar
Run the bags.
Two Firestone 2500# dbl. convoluted bags w/about 10ft total of DOT 1/4" airline & 2x schrader fittings would be around $200 depending on the source.
Air them up to the ride height you want & enjoy the ride. Occasionally you'll have to put some air in (just like a tire occasionally requires air), but for the most part.... it's set 'em & forget 'em. Like BTD suggested, it's always wise to keep an emegency air source if possible.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-19-2007, 10:56 PM   #10
BigTruckDriver
I am know suspension expert myself but remember reading some where that a 6" spring is pushing it. For a 6" drop its best to go with a 4" spring and a 2 " block ,for best ride quality. It not a necessary to go that route but you get a spring with enough space to work better. To use a 7" drop spring there just is not enough room for the spring to work the way it supposed to.
