Old 06-16-2007, 07:55 AM   #1
one9six9
Junior Member
Used Transmission
I need a transmission. I'm trying to get by as inexpensive as possible since I don't really know how long I will have a three speed set up, but I don't have the money free to upgrade to the 700r yet.
I have a turbo350 with my 250 I6. I found someone that has a turbo400 that was pulled out of a 69 Chevy Chevelle two years ago. He says that it had about 5000 miles on it when it was pulled. It also has the stock torque converter. I don't know what size engine was in the car, but he thinks that I will have to get a new torque converter because the flywheels are not the same. If this is correct and the flywheels are not the same can I just swap flywheels, or are the bolt holes different from one torque converter to another?
Oh yea, is there anything that I need to look out for on a used transmission, or is there anything that can be checked being that the transmission isn't installed in a car?
Thanks,
Keith
one9six9 is offline   Reply With Quote
Old 06-16-2007, 08:35 AM   #2
cdowns
cdowns's Avatar
Re: Used Transmission
you know you'll need to shorten your driveshaft for a 400tranny
Old 06-16-2007, 08:42 AM   #3
killer71
killer71's Avatar
Imho if i were you financially i would save my money until ready for the 700r. wouldn't waste my time/money on modified shaft, my time, possibly problems with turbo 400. But that's just me!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-16-2007, 01:42 PM   #4
one9six9
Junior Member
I didn't know that I would have to cut the driveshaft. I thought the 400was just a stronger version of the 350. I don't have the funds for the 700 right now, and the transmission I have is not driveable.
Would it be a nightmare to rebuild it myself?
Keith
Old 06-16-2007, 03:25 PM   #5
mnunn454
mnunn454's Avatar
Rebuilding either would/can be a nightmare if you aren't well equipped and very patient and careful with the details.
Saving the money for a 700R is nice, but if you need a tranny now, assuming the 350 and 400 have the same length tailshafts, the used TH400 should be an easy replacement for the 350.
You will need a larger front slip yoke for the driveshaft (TH400's output is larger than the TH350's) and probably a special U-joint, but you shouldn't have to cut the driveshaft until you go with the longer TH700.
I don't think you'll need a new flexplate. The TH400 converter should bolt up right where the TH350's did onto your existing flexplate. I think you could even use your TH350 converter and flywheel if you wanted to because TH350and Th400 converters are usually interchangable.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 06-16-2007, 03:45 PM   #6
70GMCer
70GMCer's Avatar
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-16-2007, 06:58 PM   #7
another thing to remember is the T400 equipped truck came with the high tunnel. I am not sure if they would squeeze int there of a low hump cab. Sure it would, but it would be tight for cooling. To go from a T350 to T400 requires a lot of changes and the money spent on those changes may not be worth it.
You maybe able to find another T350 (V8 or 6) or 2004R overdrive (same length as the T350 in trucks) to swap yours out with.
The T400 will bolt in, but the other stuff you need, drive shaft mods, new yoke might not make it worth the money. We have some pick & pulls that normally have decent prices on used tranny's and they normallly tand behind them too.
Good luck on your find.
Old 06-16-2007, 07:05 PM   #8
earl87gta
earl87gta's Avatar
I would think you can find a used 700r4 for not much more then that 400 would be you can probly by a old camarro or firebird with a 700r4 in it for almost nothing and sell what s left of the car.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-16-2007, 08:17 PM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
None of my small block trucks with the TH400 have high humps...I think that was just the big block trucks.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-16-2007, 09:12 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that's right, TH400 did not dictate a high hump at all... only on 1/2 ton GMC trucks with the v-6.
A Th400 converter will not bolt onto a flex plate that was made for a Th350.
I don't know about swapping flex plates from an inline to a small block.
Persoanlly, I would look elsewhere for a Th350.
If you trust this cat, and the tranny is dirt cheap, I'd buy it just for trading material... some one with a TH350 may trade you even up.
