Old 06-24-2007, 02:13 PM   #1
Razmataz
late model 16" rim's for 65 c-10 ??
Does anybody know if any late model stock alum 6 lug 16" rim's would fit on a 1965 chevy c-10 ?? If so which models would fit ?? Thanks
Razmataz is offline   Reply With Quote
Old 06-24-2007, 04:06 PM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: late model 16" rim's for 65 c-10 ??
Nope, the factory ones do not. The center hole on a 10 bolt axle is smaller then on the rear axle that is under your truck. I guess you could machine the wheels to open up the center hole. I bought a set of steel wheels from for friends 06 chevy, and found out they didnt fit due to this problem.
PrerunnerRob is offline   Reply With Quote
Old 06-24-2007, 04:15 PM   #3
LILRED66
LILRED66's Avatar
Razmataz:
American Racing, Weld Wheels and Eagle Alloy makes wheels that will fit the '60-'66 Chevy trucks with six lug and eight lug hubs. I just bought a set of 17" eight lug Eagle Alloy rims for my '66 Chevy K20. I also have a few other trucks with aftermarket six lug rims. There are countless aftermarket wheel styles available for these trucks. Here a few examples:
LILRED66 is offline   Reply With Quote
Old 06-24-2007, 04:35 PM   #4
Razmataz
If you bore out the center hole for clearence , Then could you use like late model tahoe or gms rim's ?? or would there still be another problem ??
Old 06-24-2007, 04:48 PM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
It will work but the offset is a little shallow!!!
72freak is offline   Reply With Quote
Old 06-24-2007, 04:58 PM   #6
PrerunnerRob
If you machine the center hole, I dont see why it wouldnt work. Just check the caliper clearance up front, the fender clearance, and you should be good to go! Just be sure to a have a spare bored for if you get a flat.
Old 06-24-2007, 05:06 PM   #7
slepysal
slepysal's Avatar
most after market rims as mentioned by LILRed will work. They uasaly come with the larger center bore, and hub centric rings.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-24-2007, 05:41 PM   #8
Razmataz
Ive got stock drum brakes, There are a lot of good deals on factory take off wheels & tires ! 16" rims should clear the drums , or would I need spacer's for the front not to rub against something ?? What's the offset difference between stock and a late model chevy ?
