Old 09-20-2002, 10:36 PM   #1
Crank
Crank's Avatar
Later Model Axle
Would an axle from a later year chevy truck, like a 12 bolt, work under a 67? Are they the same length? If you took the spring perches off the axle and added whatever you needed to put it under one would it work or would it be wider? Thanks.
Brandon
Crank is offline   Reply With Quote
