Old 08-06-2007, 05:50 PM   #1
hewlett2002000
hewlett2002000's Avatar
a few questions........
ive been posting my questions in separate posts so im just gonna ask them all here. here it goes...
what is a good replacement for the stock accelerator setup? i would like a cable set up.
i am changing fro my Saginaw 4spd to a th350. will a powerglide crossmember and yoke work on the th350? if the glide crossmember will work can i bolt it where it would go stock on my truck or does it need to be in a different location?
how hard would it be to put the e-brake in the floor? (just an idea)
is there any 6 lug rotors for my disc brake setup in the front?
when i change to power brakes will the rod on the brake pedal be too long or short to go in the booster? what if i just use a master cylinder from a disc/drum car or truck?
thats all i can think of right now. i appreciate any help you can give.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
