Old 07-30-2007, 06:28 PM   #1
bazkook
What is biggest size tire I can fit under my pickup?
I have a 1970 Chevrolet C-10 pickup that I am restoring. I want to go for the Pro Street look with the big rear tires,both for maximum traction and good looks, and skinny front tires. I plan on lowering the truck about 2 inches as well. I want to get the biggest tires in the rear,in diameter and width, as possible without them rubbing or interfering with other components or without resorting to a narrowed rear end or tubs. I will probably just go with 15" wheels BTW. What's the biggest I can go? Also what kind of backspacing will I need? Is there a chart on the internet where I can look up tire sizes for particular vehicles?
bazkook is offline   Reply With Quote
Old 07-30-2007, 07:34 PM   #2
Big White GMC
Big White GMC's Avatar
Re: What is biggest size tire I can fit under my pickup?
It Depends On How Wide Your Wheels Are, Backspacing, Ect. I've Got 15x8.5 Wheels And Have Had 255/70/15 Eagle Gt II Tires On It. I Had A TON Of Room Left Up Front. If Your Gonna Go Pro-Tour I'd Suggest A-Arm Upgrades ( Tube ) And A Spring Change First Off. A Little More Money Spent But A World Of Difference As Far As Ride And Grip. As Far As Tires.... Couldn't Tell You. From Personal Experience, I'm Enjoying My New Toyo Proxes ST's. They Are 275/60/15. They Will Help As Far As Sidewall Flex And Wet Traction. Out Back, I'd Do Springs, A New Panhard Bar ( Assuming You Have Trailing Arms. ) , And Sway Bar. Early Classic Has All Of That Stuff. Good Luck, Man. Let Us Know What Happens.
Big White GMC is offline   Reply With Quote
Old 07-30-2007, 08:00 PM   #3
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I have 15x11 with 5 1/4 backspacing 275 60 15 bfg with no clearance issues
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 07-30-2007, 10:19 PM   #4
Richard H.
Spanked once
Richard H.'s Avatar
bump,
Richard H. is offline   Reply With Quote
Old 07-30-2007, 10:30 PM   #5
bazkook
I was going to upgrade the suspension of course, mainly to go straight. The truck has been sitting for a long time anyway so I figure now's the time to do it. I will probably put some traction bars in the rear and a fuel cell and battery in the bed to get some weight back there. BTW, I don't know whether this makes a huge difference or not but I have a stepside. I've heard stepsides can fit fairly big tires but how much bigger than fleetsides I don't know.
As far as tires go, I've been looking at either the M/T Sportmans or ET Drag Radials. ET Drag Radials come up to about 29" so I fairly sure they'll fit no problem. But I would like the tire to fill up the wheelwell as much as possible.
Old 07-30-2007, 10:55 PM   #6
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Here's another truck I built 15 x 10 slots with 31x10.5x15 with 4''back space wheel lowered about 4'' no clearance issues.
Old 07-30-2007, 11:31 PM   #7
1970bowtie
1970bowtie's Avatar
i got 15X10's with 295/50's, not sure of back spacing but their American racing outlaw 2
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 07-30-2007, 11:56 PM   #8
bad6772
Official Site Guitar Shredder
bad6772's Avatar
in the rea i run a 335x55-17, i will check back spacing for you, my rear rim is 12 inches wide and although it is very close to the inner wheel tub.qbout 1/2 inch. ive never had any rubbing problems, unless i got on it hard from a dead stop. with a posi unit. it tends to get a little sideways from time to time
bad6772 is offline   Reply With Quote
Old 07-31-2007, 11:35 AM   #9
bazkook
When I get the truck drivable,I'll see if the local tire guy,whom I know well and have done a lot of business with, will let me use some extra tires he's got laying around to see what will fit and what won't.
Old 07-31-2007, 11:52 AM   #10
Big White GMC
These Trucks Can Run Some Big Tires With Not Much Of A Fuss. Stepsides Are Able To Handle About Anything You Can Throw At Them. BTW, Are You Lowering The Truck? Cause If So, That Throws A Few More Wrenches Into The Works. As Long As You Don't Go Crazy With The Drop, You Can Run Whatever.A 2/4 Drop Is Good, But Anything Lower You Run Into Front Clearance Problems.
Old 08-01-2007, 11:14 AM   #11
bazkook
I'm not into slammed trucks so I won't go crazy with the drop. However,I have the stepside with the spare tire on the driver's side and the cutout in the wheelwell. Will this be a problem trying to fit a big tire on the driver's side?
Old 08-01-2007, 11:22 AM   #12
Big White GMC
Yeah, I Could See That Spare Tire Hump Being A Problem. You Could Move The Spare Under The Bed, Unless You're Going To Put The Gas Tank There. Then I Guess You'll Have To Go Commando, So To Speak.Worse Case Is A New Wheel Housing On That Side Of The Truck. I've Never Liked The Idea Of That Spare Tire Holder On The Side Of The Bed.Too Easy For " People " To Gank Your Spare.American Racing Has A Program That Shows Their Wheels On Your Truck. That Might Help.
Old 08-02-2007, 12:32 AM   #13
bazkook
I'll probably just ditch the spare altogether. I plan on using a fuel cell in the bed anyway and take the gas tank out of the cab. I might just have to use a new fender anyway because the original is pretty rusted,just like the rest of the truck. I never liked the spare tire holder on the side either. It seems to me that it would really shift the weight to the driver's side more.
Old 08-02-2007, 09:40 AM   #14
70cst
70cst's Avatar
I have 275x60x15 on all fours and I am have a slight rubbing issue on the fronts. I have a 2-4" drop. Truck is a 70LWB. The wheels are 15x8 5 lug truck ralley's. I think I will drop to a 225x15x60 up front so I get away from the rubbing issues. I too thought I would have plenty of room up front but not so.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-02-2007, 12:01 PM   #15
Big White GMC
I'd Go 255/60/15 On The Front. A 225 Would Look Tiny Compared To The 275's Out Back.
Old 08-02-2007, 01:13 PM   #16
70cst
70cst's Avatar
Thanks Big White GMC on your recommendation. After reading your suggestion I think you are right. I will go as large as possible w/o rubbing. Thanks again!!!
Old 08-02-2007, 11:07 PM   #17
Big White GMC
No Prob, Bro. I Think These Trucks Look Soooooo Good With Some Big Meats In The Fenders. A 265 Might Be As Big As You Can Go Up Front With That 2'' Drop. Is The Drop Done With Springs Or Spindles ?
Old 08-03-2007, 12:41 AM   #18
70cst
70cst's Avatar
Spindles...
Old 08-03-2007, 07:09 AM   #19
67shortie
Green club
67shortie's Avatar
I am runing a 285/70/15 in the wheelwells of my fleetside, I am not sure how these would look in a step bed though?
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 08-03-2007, 07:13 AM   #20
70c10
67-72 Addict!
70c10's Avatar
67shortie your truck looks slick! I run 275/60/15 on all 4 corners with no rubbing dropped 2.5" in front.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-03-2007, 09:52 AM   #21
68Stepbed
68Stepbed's Avatar
I would also suggest the 285/70/15 rear with a 235/70/15 front for a prostreet look. If you want good traction, look at some of the drag radials. I think Mickey Thompson makes a 295/60/15, which is about 29.5" tall. I've seen 6" rear drops without clearance issues with these tall tires.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-03-2007, 09:53 AM   #22
rcheesem
rcheesem's Avatar
I have 15x10 all around. Front tires are 255 60 15 and the rears are 275 60 15's. No rubbing issues. The truck was already lowered when I got it but it's not lowered much. Not sure exactly how much.
rcheesem is offline   Reply With Quote
Old 08-03-2007, 04:24 PM   #23
67Style
295/65/15 MT drag radials. 3/4 drop. No problems...
67Style is offline   Reply With Quote
Old 08-03-2007, 04:32 PM   #24
whatnow123
whatnow123's Avatar
Does this look like model or a miniature truck? The way it's photographed it looks fake. Cool, but fake
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 08-03-2007, 04:42 PM   #25
ratrod67
ratrod67's Avatar
15X10 with 5 inch backspacing and P315/60-15's with a 6 inch rear drop.
ratrod67 is offline   Reply With Quote
