how much to cut?
can someone tell me how much I need to cut off a stock set of front springs to get 3".I know if you cut 1 coil it will drop it 2" but how much for 3".it's on a 1970 1/2 ton.thanks
Dave's not here, man
Re: how much to cut?
I cut 1.5 coils and got about 3.5" However, I wouldn't recommend doing this. The truck rode like crap, and you could hear the spring bouncing around in the pocket when you went over bumps.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
The rule of thumb is cutting 1 coil = 2" drop but not all springs are equal. You might get 2" on one truck & 3" on another.
Cut 1 coil & put them back in to see how much drop you get.
67-72 Addict!
1 and a quarter coils cut off will give 3" of drop.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
i dont suggest doin that just buy 3'' drops
alot less hassle |
I just want to do this to get me bye until I can get bag's.it's not a daily driver.thanks for the input
#7 | |
Warning: Some trucks have issues w/running out of threads on the upper a-arm studs when cutting off enough coil to get 3" or more of drop. You might have to get new, longer studs if you go this route.
#8 | |
F.A.S.T. president
![]() Join Date: Sep 2003
I have 3 " springs and I ran out of threads to get my caster adjustment like he said. I bought longer studs and made 1/2 spacers, so I dont have such a large shim stack.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 07-04-2007 at 09:10 PM. |
thanks guy's.I have 1 coil cut right now and I'm just waiting for some cooler weather to put them in.
Did you install them yet? I am real curious how it looks and how much room on the bump stops. Please keep us posted. My truck is not A daily driver either and I would like to do this MOD.
![]() Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
if you go with aftermarket coils will you still run out of threads?any pics of the bolts you need to change?i was planning on cutting 1.5 to 2 coils when i swap on the disc setup.
#12 | |
The exceptions to this rule are adjustable a-arms or re-designed (shortened lower/stretched upper) a-arms.
