Old 04-30-2002, 08:46 PM   #1
69Burb4x4
Question Need transfer case information
I (obviously) have a 69 3/4T 350 4spd Suburban. It is completely stock. Does anyone know what transfer case and axels came on it? I think it has a Dana44 in front, a Dana60 in back, and a NP205 transfer case. But I can not verify that anywhere. If anyone knows where I might find this information please let me know.
Thanks a million,
~Neil
69 3/4T Burb 4-spd 4x4
69Burb4x4 is offline   Reply With Quote
Old 04-30-2002, 11:03 PM   #2
Hawk
Post
Hey '69, chances are you have exactly what you think you have. But just in case, the 205 case has a metal plate screwed into the case just below the shift rails on the front side of the case, that plate should say on the left hand side Model 205...if it does, it's a 205. Checkout some of the websites if your plate is missing.
As for the axles, both will have a number stamped into the axle housing, I think on the upper right hand side.......the stamp will be "44" and "60" for a Dana 44 and Dana 60 respectively. I could be wrong about the location.....its been awhile since I cleaned mine off.
Either way I hope this helps.
See ya'
Brian
Finally a rolling chasis with 1-ton axles all the way around.
Bristol, TN
67 K10 swb, fleetside
Cab on the frame..............one step ata' time folks.
Bristol, TN
Hawk is offline   Reply With Quote
