Old 09-28-2002, 11:03 PM   #1
chevynut
chevynut's Avatar
What year tilt column???????
I have a tilt column that I pulled from a 67 Chevy but it has a GMC horn cap, so I am thinking it is not original.
How can I tell what year truck it came from?
Mike
1989 C1500 SWB Reg Cab
2003 Chevy Tahoe Z-71
70 Camaro RS/SS - 454
chevynut is offline   Reply With Quote
Old 09-29-2002, 11:48 AM   #2
Rod
Desert Rat answered a similar question here.
http://67-72chevytrucks.com/vboard/s...threadid=25689
Tilt did not come in 67 so I may be a correct tilt with a 67 steering wheel with GMC cap or it could be a van column with a different steering wheel. Check the length of the shifter arm... if it appears short it will be van column possibly, also check the lenght of the shaft coming out the bottom also... if its about 5 inches long its a van column also. Neutral safety work?
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
