Old 09-19-2007, 07:11 AM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Will a 15 x 10 rear wheel/tire setup fit a stepside??
I know that some guys here on the board run 15x10's on the rear of thier fleetsides, but to me it looks like that the well for my stepside is a narrower. Is that just an illusion? I plan on going with 4.5" offset Corvette Rallys. does anyone see a problem????
I want to float this question out there before I buy something that doesn't fit!!!!!
thanks guys.
tcb-1 is offline   Reply With Quote
Old 09-19-2007, 07:24 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Will a 15 x 10 rear wheel/tire setup fit a stepside??
You should have no problem.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-19-2007, 08:23 AM   #3
69_hafton
Sleep-Deprived
69_hafton's Avatar
I was looking for the same info - I saw some 15 x 10" truck rallies on ebay - 4.5 offset and thought those would help fill out the rear wheel wells better but didn't know if that was the best offset to go with / or what tire size will fit. 275 60 15?
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 09-19-2007, 09:00 AM   #4
69c10step
69c10step's Avatar
I had 15 x 8 Rallys with 4-1/2'' bs wrapped with 275/60/15's on my '69 step - they were very close to rubbing against the bed wall on the inside of the tire. I could just slide my fingers between the two.
A couple weeks ago, I got my wheels back from being widened to 12'' with a 7-1/2'' bs. Cut the bedsides, installed wheel tubs inside the bed, and now the 31 x 16.5 x 15 M/T Sportsmans fill the space nicely. or maybe
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
