Car 4spd Shifter Ideas?
What have you all with 4spds done to keep the shifter out of the seat?I`m bringong an M22 home today.After going through it I`ll mount it and the fresh 327 in the frame so I can mount the cab.Man...just typing that gets me stoked.It`ll be a long haul getting this done.But,a cab-on-frame starts looking like a truck.There`s more to it,I guess.I want to get exhaust run while it`s just a rolling frame so it can be cut through the trailing arm crossmember.But,a motor/trans set-up is some major progress,anyway.
Junk/Daily Driver Club
![]() Join Date: Feb 2004
Re: Car 4spd Shifter Ideas?
I had one in a low hump truck. The bellhousing was in the 6 banger position, the small block was cloes the the firewall. I used buckets and mounted the console back enought to clear it.
Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. ![]() There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
the easy way is to just make a new shifter handle they only bolt on with 2bolts // i 've used thin plywood to fool around makin a template then once you've got a height and geometry that clears everything and feels good trace on to 1/4inch plate weld a piece of threaded rod for shifter knob then either paint powdercoat or if budget allows chrome it
That`s what I`m considering.I`ll get dimensions once mounted in frame and use body perches for reference.I know guys just reverse the car shifters.But,that`s a bit funky for me.Hurst sells all kinds of levers.I wonder if a straight one would work out.I have a taller truck lever from a "His,n,Hers" set-up that just curves near the top.It`s pitted pretty bad,but can use for a mock-up,too.I want good throw action or I`d go the tall stick with mower piston or skull for something funky
Used Register
I've seen some pretty odd shifter set-ups. In some I've seen setup to work with a bench seat, the handle is a C shape with the knob pretty much directly above the mount, but the handle goes forward first, then turns up, then turns back toward the rear for the handle. Something like that with a taller vertical section may work.
The plywood mockup idea is an awesome one! If you fab you own, remember that is does not have to be flat - you can bend it or twist it toward the driver. Herb |
Real Projects never die
55-57 chevy bench seat shifter, thats the one i have heard works.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
#7 | |
Used Register
"I'm trying to install a Hurst shifter into my '55-57 Chevy, but it seems like the stick is going to be under the bench seat. For '55-57 Chevys, Hurst uses a special stick shaped like a large "C" to clear the original bench seat. Due to the extreme angle that the stick comes out of the mechanism, it was not possible to make it a bolt-on stick. It is welded into the mechanism, like the 65-70 Mustang shifter. The stick is not available separately, and can only be ordered with the shifter under part #391-3780." There is a picture of it in this pdf: http://www.lowridertechnology.com/im...l_shifters.pdf Herb BTW - I'd have sworn I saw it as a separate stick - maybe it was seen during a shifter rebuild. With the extra height of the truck, you could possibly make it a bolt-on. Last edited by herb101; 09-16-2007 at 09:32 AM. Reason: more more more |
Yeah, my dad bought a hurst for his 55. Now he has decided to go with buckets so he told me I could us ehis shifter if it will work. Its still brand new in the box.
www.fatdaddieshotrods.com |
WTB this ad
How about this un?
![]() Or? ![]() Throw in a little........ ![]() Or you could go with....... ![]() And finish up with........ ![]() |
Old Skool Club
![]() Join Date: Jun 2001
I bought a Hurst Indy shifter for an '81 El Camino, and had to change the stick because it would hit the seat of the Elky. But, I still have the stick, and it's about 6-inches long, not counting the knob. It straight, bolts on and (best part) you can have it for the shipping from 72015.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Always on the hunt...
![]() Join Date: Sep 2006
Special, I have always loved the look and feel of the original type 64-67 chevy muncie shifters and handles, there are atleast 6 different (due to console/no console/bench seat/big car/small car variations) shaped muncie shift handles that I have seen and or had over the years. Along with the 67-72 trucks, it is 61-64 impalas that take up the rest of my available time
Great info,all.I love the feel of the hurst/4-on-the-floor set-up.This shifter was for a`71 El Camino.I got the aluminum V8 bell housing,so I don`t need to change crossmembers.
I wonder why a straight stick wouldn`t work.It seems the 55-57 car shifter ends up with the nob over the base and our seat tops are father up from the trans.
#15 |
ttt for more 1st hand experience.Or,should I say right hand experience?
#16 |
Hurst makes a shifter and install kit for chevy trucks; I think the install kit is the big difference because it includes a mount that puts the shifter farther front on the trans. My engine is in the more forward mounting holes in the frame. Here's mine with a super t-10 (I'm sure a muncie would end up the same) It's in first then second gear... I've considered going with a straighter stick, but first would move way up with a straighter stick.
![]() ![]() Last edited by Jim_PA; 09-17-2007 at 11:39 PM. |
#17 |
There ya go!I have the buddy buckets.Do you think that later seat sits about the same height and same position at the front?I guess if it`s made for these it`ll work.Do you have a part#?
#18 |
shifter is 391-0002
install kit looks to be 373-7834 for an m22 I got mine from a shop in New Jersey (streetwise performance). The shifter and linkages were new, the stick was used for about $225. To buy it new, it's about 350. I also got my super t-10 rebuild kit from them. Seem to be very good people to work with, and they were familiar with a truck install. Their 4-speed guru seems to be very knowledgable. I used the factory mounting holes for the front of the seat. The back of the seat doesn't quite reach the rear hump, so it sits down in the back, which is better for me, since it leans me back a bit to clear my long legs. I would imagine that the factory seat would sit about the same in the front as mine does. |
#19 |
Thanks alot Jim.Jeez!That much just for a shift handle?They must have bumped their head.I know shifter/levers went throgh the roof thanks to investors deciding the like muscle cars,but that`s insane.The shifter kick costs that much with a lever already,but just a lever for over $300?I have one like that from my "His,n,Hers" that I doubt cost more than $25.I know that was awhile ago.That was when you could buy a used 4spd for $100-300 all day long when these "investors" were driving Corrollas.I could have a custom-made one made for 1/2 that,I`m sure.
Sorry about the rant.You get good info only to find what a rip-off what you want is.Who would pay over $600 just for the shifter/lever?I thought I was nuts!! I have a guy in Lansdown,PA that my kit came from that rebuilds them.I`ll check with him on a shifter set-up.Thanks again for the numbers.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-18-2007 at 06:08 AM. |
#20 | |
#21 | |
391-0002 http://www.jegs.com/webapp/wcs/store...-0002&x=11&y=4 373-7834 http://www.jegs.com/webapp/wcs/store...-7834&x=20&y=6 If nothin else, give Hurst a call and see what they tell ya. ![]()
#22 |
OK,shew!!I knew shifters were over $300 complete.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-19-2007 at 05:01 AM. |
