Old 09-23-2007, 09:15 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Alternate To Wood for A Stepper Bed???
Wood Bed in My Project Truck is Shot & will need Replacing, Just wondering if anyone has Come up with Alternate to using Wood?? What Did you Use & How did you Do it?? Any Idea's On This would be Appreciated...........
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 09-23-2007, 09:17 PM   #2
1969k10stepside
Re: Alternate To Wood for A Stepper Bed???
I'll probably just use a sheet of plywood in High Step for now but would like to get some Diamond Plate for it eventually..
1969k10stepside is offline   Reply With Quote
Old 09-23-2007, 09:48 PM   #3
Boog
laying low
Boog's Avatar
Well for most show trucks wood is the norm. Metal sheet is often used for a daily driver/ work truck. I am giving some thought to using a composite type home deck material. Trex is one brand, there are several. It's not cheap but it is durable and will not rot and comes in different colors.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-23-2007, 09:51 PM   #4
see ten
WTB this ad
see ten's Avatar
There was a member who used Trex and posted some pics quite some time ago. I don't remember who it was but it seemed to look and work quite well for a daily driver.
see ten is offline   Reply With Quote
Old 09-23-2007, 10:25 PM   #5
toomanytoyz
Luv the Crewcabs
Found Link With Search , But His Pics no Show. I'm Gonna Pm to see if he can Repost Them, Thanks for Posting that Info..........
Rick
His Link............
http://67-72chevytrucks.com/vboard/s...highlight=trex
Old 09-23-2007, 09:53 PM   #6
toomanytoyz
Luv the Crewcabs
Thanks for the Input, Also Thought about Putting Steel down & Having the whole bed Herculined also, Would like too See That if anyone has Done it??????????
Thanks Again, Rick
Old 09-23-2007, 10:11 PM   #7
jorgensensc
jorgensensc's Avatar
I have also considered using some type if silestone countertop , or other engineered wood instead of actual wood. Although if you take care of it the wood we have now will last a really good while.
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-23-2007, 10:38 PM   #8
The wood lasted a long long time.In a highly cared for classic it will last even longer.In many cases the sheetmetal rusted before the wood rotted.I built a pro-street Stepside and used a steel Fleetside bedfloor and wheelhouses.
Old 09-23-2007, 11:05 PM   #9
toomanytoyz
Luv the Crewcabs
Would u have any Pics of this you could Post???
Thanks, Rick
Old 09-23-2007, 11:15 PM   #10
Gray Ghost
Gray Ghost's Avatar
Trex is very expensive....for the money you would spend on that stuff [and it's not even waterproof] you could have a very nice wood bed. I am 90% sure Trex doesn't come in 1x8 size for the big boards....not sure what you'd do since Trex cannot be glued up like normal wood.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 09-24-2007, 02:36 AM   #11
2bits
2bits's Avatar
I put in a sheet of the most expensive 3/4' Birch plywood Home Depot had. ($30), wanted to get the thickest veneer possible. The bed was 3/4" too wide for the sheet, so had to add a "frame" around it, but I still think it came out great and I load all kinds of stuff in it, including my new engine, and it is very solid. Not sure how wide a standard bed is, mine is pretty rigged up, so I don't know how a standard 4 foot wide sheet would fit on a "good" bed. Going to do Pine and build myself (with Kelly's help i am sure ) and do the normal wood bed kit when I install my replacement bed.
Link to the page for all the pics of the install:
http://www.grossepointegothic.com/71stepside/woodbed/
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 09-23-2007, 10:42 PM   #12
68 P.O.S.
Mikenutt has the composite stuff in his bed. I've seen it in person and I though it looked really cool. I plan on borrowing his idea when I get to that step.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 09-23-2007, 10:47 PM   #13
ksjh1316
ksjh1316's Avatar
I have heard that stuff bleachs out real fast in the sun any truth to this?
ksjh1316 is offline   Reply With Quote
Old 09-23-2007, 11:02 PM   #14
I think Trex is fugly.I use it alot.Sierves it`s purpose,but looks like particle board,IMO.
Old 09-24-2007, 07:28 AM   #15
Orange Truck
Orange Truck
I would stick to wood. I used the oak kit from the firm in Oklahoma. This is class stuff. It comes groved and holes drilled and counter sunk. Although already finished, top it off with a sand of the finest paper and three coats of marine varnish. Then dress it up with polished stainless stell strips and fastners.
Orange Truck is offline   Reply With Quote
Old 09-24-2007, 09:11 AM   #16
lilred67
lilred67's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=195408
here is a link to some pics of my steel floor i built....the cost was around $150.00. steel has gone up since then....
lilred67 is offline   Reply With Quote
Old 09-24-2007, 11:39 AM   #17
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
I think some kind of composite decking material would work great if you want the look of a wood bed, but not have to worry about messing up a nice new wood bed. As far as size of the planks compared to the original...just drill new holes for the 5 1/2" or so wide composite
Sequoyah is offline   Reply With Quote
Old 09-24-2007, 12:19 PM   #18
Chris H
72 C30 Trailer Queen
Chris H's Avatar
http://www.rumber.com/truck_products...ruck_beds.html
Here is a website for "rumber", which is a rubber composite lumber product (sheets and boards). Manufacturer makes it sound bombproof.
IIRC, there was a red stepside truck here that had a similar product in his bed?
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 09-24-2007, 12:38 PM   #19
Rdub
At a car show, saw a polished stainless floor and then chrome wood bed hold down strips were applied..... looked very nice.... depending on the intended use, aluminum could also be used with the chrome wood hold downs or some other type metal strips, chrome, polished alum. or stainless. I have a short step which needs a new bed and I think at this point some type of metal bed with metal strip hold downs is what I'm planning.
71 GMC 1/2 ton 4x4, 350, 350th
67 chev short step, 396, 350th
41 chev flatbed, custom bed, frame & suspension, 350, 350th
Rdub is offline   Reply With Quote
