Old 09-28-2007, 11:44 AM   #1
Rokcrln
Rokcrln's Avatar
Has anyone moved their pedals for more room?
I did alot of driving in Low Buck this last week (300 mile trips for work) and found that I am getting older or just warn out but my knee's start to ache and I need to move my pedals forward a few inches. I hope toget about 3" out of the pedals and 3" by getting a new bench seat or have mine re worked to thin out the back. I have room in th eengine bay to cut the pedal box and relocate parts of it forward. Then I would need to modify the brake pedal to set it back 3" along with bending the gas pedal some as well. Has anyone done anything like this or other mods for more leg room short of streaching the cab or getting a different vehical?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-28-2007, 12:09 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: Has anyone moved their pedals for more room?
Kevin, moving the pedals is too easy for you, I think you should do this instead:
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-28-2007, 12:57 PM   #3
Rokcrln
Rokcrln's Avatar
I am looking for easy because I don't have the time for more than that right now! Also I have too many projects lined up to do it later. Low Buck drives and rides so nice now that it has the LT1 and 700R4 in it that I done what to put it down for any length of time or it might get shoved to the back burner
Kevin
LFD Inc.
Old 09-28-2007, 01:21 PM   #4
brianthelion02
Overdrive club
brianthelion02's Avatar
Talking Re: Has anyone moved their pedals for more room?
Best pedal modification i did was eliminating the clutch pedal
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 09-28-2007, 03:05 PM   #5
fastom
That's right, it's Copper!!
fastom's Avatar
I'm in the process of assembling the inside of my truck. I've been working with the pedal mounts for a few hours now and I can't think how you would move them without redesigning everything.
Good luck, let us know how you do it!
fastom is offline   Reply With Quote
Old 09-28-2007, 03:07 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you have relocated the fuel tank, you can trim the back wall where the seat hits it, so the seat can go back further. (remounting the seat is required) You'd have to do something about the sharp edge left there, but that should be fairly easy to come up with something on that though.
Old 09-28-2007, 07:41 PM   #7
Jim_PA
I mounted my seat up a little higher in the front, so, it sits down lower in the rear, which lets my legs come to rest higher in the front of the seat... it helped a good bit. Not perfect, but more comfortable to drive. I don't feel like I'm constantly holding my leg up in the air anymore, but I could still use more leg room.
Jim_PA is offline   Reply With Quote
Old 09-28-2007, 09:26 PM   #8
ebfabman
Doesn't need to be a sharp edge. This mod can add about three inches of leg room
ebfabman is offline   Reply With Quote
Old 09-28-2007, 09:30 PM   #9
ebfabman
Just be aware that moving the seat back put your head closer to the back glass
Old 09-28-2007, 09:39 PM   #10
herb101
Used Register
herb101's Avatar
Maybe you could retro-fit the electric adjustable pedals from the later trucks (some Fords had them).
Herb
herb101 is offline   Reply With Quote
Old 09-28-2007, 09:48 PM   #11
Rokcrln
Rokcrln's Avatar
Herb
Yes but this still would need mods to the floor at the base of the fire wall to give the pedals somewere to go.
I checked my truck and with the stock seat it is already touching the window rubber right now so I can not see how this would help with my set up. I guess if my seat tilted then I could slide it back some but with mine not being a flip forward style I am stuck. My seat does have alot of padding in the back ( 6" thick) that can be redone with better foam to thin things out a bit.
Kevin
LFD Inc.
Old 09-28-2007, 11:49 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my seat back is also fairly thick, probably 4.5-5". I've often thought if I had one of the thinner ones I'd gain some legroom.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-29-2007, 12:07 AM   #13
drman929
drman929's Avatar
I'm eager to see the achievement...so hurry up!
Hey...when did low buck get a LT1 and 700r? I didn't see that thread!
drman929 is offline   Reply With Quote
Old 09-29-2007, 12:16 AM   #14
red69ss
Burnouts are therapeutic
red69ss's Avatar
I Adjusted Rod That Goes To Brake Booster And Got Mine About 2 Inches Closer To Floor ,now I Don't Have To Pull Knee Into Chest To Hit Brake Pedal.......mine Does Have Disc Conv. Kit On It So It May Be Different.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 09-29-2007, 12:16 AM   #15
ebfabman
I should qualify that trimming the lip around the fuel tank will only be useful under 2 conditions 1) the fuel tank is removed from the inside of the cab, and 2) the thick backed stock seat is replaced with a seat that has a thinner back and is positioned where it will fit under the rear window. There is a wide range of seats that will fit without much work.
Old 09-29-2007, 01:58 AM   #16
Rokcrln
Rokcrln's Avatar
"Shell Games" in the project threads! It is the best combo I have ever had. And I have had alot
Kevin
LFD Inc.
Old 09-29-2007, 02:44 PM   #17
2500HD
2500HD's Avatar
[QUOTE=ebfabman;2379610]Doesn't need to be a sharp edge. This mod can add about three inches of leg room
[/QUOte
This is exactly what I had in mind to do. Do you have any pics with the seat in?
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
