Old 05-01-2002, 08:07 PM   #1
GMC 3
Post removing windshield glass?
What do I have to do? I Took out the rear window without damaging the rubber using 5 or 6 small screwdrivers and 2 people. Is taking out the windshield similar, or should I just cut the rubber to take out the glass? How hard is it to put back in?
thanks
GMC 3 is offline   Reply With Quote
Old 05-01-2002, 08:16 PM   #2
69 longhorn
Post
I would just cut the rubber,& replace it .....much easier.......69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-01-2002, 08:31 PM   #3
zyggy72
Can't kick the addiction!
Post
Rather replace the rubber than replace the windshield.
zyggy72 is offline   Reply With Quote
Old 05-01-2002, 09:00 PM   #4
hjalbert
cracker
hjalbert's Avatar
Post
its funny this comes up today, this is the day i had my "windshield experience. i finally got arounfd to replacing the one that got broke when the hood flew up with one that i had taken out of a parts truck. for starters, a new gasket costs 50 bucks, a new windshiel, 115! so theres one tip, but if you do decide to take it out the with the gasket in one piece use lots of glass cleaner and release agent, also, dont use screw drivers, it will crack in a heart beat, id buy one of the fiber glass spatula type things they have that they use to do it, cause it will break before the glass will, also one thing to think about is that you can use old glass with new molding, but you cant use old glass with old molding or new glass for that matter, the molding gets hard and its not pliable and wont flew to let the glass in like it should, any way, i just learned all this crap today, (after they crakced my windshield, and explained why it crakced) so good luck!
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 05-01-2002, 09:15 PM   #5
truckster
truckster's Avatar
Post
With about 20 years in the glass business, I can tell you it's almost IMPOSSIBLE to remove the windshield unbroken from a 67-72 Chevy/GMC without cutting the rubber, because of the design of the curve at the top corners. The other glass (like your back window)is tempered glass, and is much stronger than float glass. The windshield is laminated safety glass- it's just two pieces of float glass with a layer of plastic sandwiched in between, and it will break much, much more easily.
[This message has been edited by truckster (edited May 01, 2002).]
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-01-2002, 09:24 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I would never even try to use a 30 year old seal for the windshield. I've seen it done, but I don't advise it.
JMO.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 05-02-2002, 06:35 AM   #7
hjalbert
cracker
hjalbert's Avatar
Post
wow, wish you would have been there to tell the guys at the glass shop, all i can tell you is that now i have a glass winshield that is "less cracked"then my old one. oh well, they didnt charge me anything, adn they filled in my rsted drip rails and the rust holes in my roof qwith polyurethane...
located in Eastern NC
1969 GMC C-10 Cab on a 1969 4x4 frame, with a 1975 350. and 4 on the floor. and now it has the wood bed from the dually.
1990 mazda RX7 conv.
72k miles mint. white
all stock
1996 toyota camry "exciting" it makes up for the gas milage of the other 2.
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
