Old 10-10-2007, 05:57 PM   #1
Matshark
Matshark's Avatar
Position of transmission yoke / ankle of rear axle
Hi Folks, I just got my rear axle and am going to install it.
ThereforI could need some advice, because the engine and transmission are not mounted yet.
I have a 4link for the rear axle which alows some ajstment for the
pinion ankle, but I would like to weld the brackets in an almost perfect position,
so that I do not have to adjust to much. I have a 97 LT1 and a 4L60E.
Here is my question:
Where would the transmission yoke be in this configuration, so that I can weld my brackets having the axle pinion aim in that direction.
Matthias
1955 2nd series 3100 Pickup, MustangII IFS, Ford 9" with 4 link, 4 wheel wilwood disc brakes, 383 Callaway supernatural, 4L60E
'All people dream, but not equally. Those who dream by night in the dusty recesses of their mind wake in the day to find that it was vanity.
But the dreamers of the day are dangerous people, for they may act their dream with open eyes to make it possible.'
Matshark is offline   Reply With Quote
Old 10-10-2007, 06:25 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Position of transmission yoke / ankle of rear axle
Usually around 2 deg to 5 deg past level. But should really be set once the engin/trans has been installed.
Brian ..
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-11-2007, 02:15 AM   #3
Matshark
Matshark's Avatar
I have to move the truck in my other garage in town.
This is why the rear axle has
to be installed even when motor and
transmission are not mounted.
I am asking because I do not want to grind
the brackets off again from the new axle housing.
Old 10-11-2007, 01:14 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I would just tac the rear suspension in place. You need to have the truck at ride hieght with the engine in it along with the transmission
I put a level on the manifold base and set it at zero. This usually leaves the transmission yoke at 3* to 5*. But not always. You may have to relocate the mounts to get it right. Then adjust your pinion to match.
Doing it with out the above steps is guessing and you most likely will have to redo the position of the pinion. So just tac it in place till you get the engine and trans in at ride level.
http://www.vibratesoftware.com/html_...aft_Angles.htm
this is a very good link on drive angles
Old 10-12-2007, 02:55 PM   #5
magsnubby
magsnubby's Avatar
When we installed the Camero rear end under my nephew's '58 step side, we spent a little time under it eye balling the driveline/slip yoke angle before ripping out the old rear end. I also notated the pinion angle degree.
Since we were flipping the axle, after we got the rear end positioned, we just tightened down the u-bolts, put a jack under the rear rear pinion, jacked it up until it looked good, then lowered the pinion angle 2 degrees. Then i tacked the spring perches, removed the u-bolts and finished welding 'em up.
This might help explain things a little better (it's talking about a 4x4 but the pinion angle applies to any vehicle:
http://www.4xshaft.com/driveline101.html
magsnubby is offline   Reply With Quote
Old 10-13-2007, 02:44 AM   #6
Matshark
Matshark's Avatar
Thanks for your help, I already
decided to only tack weld the brackets
and finish the welds when the drivetrain
is installed ( or grind them off and move the brackets )
