Old 10-28-2007, 12:23 AM   #1
Dusty4
Cheap but good rear spring ideas for 56?
I like to avoid the $400 solution, when there is a $40 one that works out just fine. And I bet lots of you guys have found springs from.... what.... more modern trucks? cars? that give a decent ride and allow for a light payload, without spending a bundle. Talk to me, fellow junkyard crawlers! And pics are even better! Thanks, Dusty
Dusty4 is offline   Reply With Quote
Old 10-28-2007, 01:32 AM   #2
lotussutol
Re: Cheap but good rear spring ideas for 56?
I have heard you can use S-10 leafs on 55-59 frames by relocating the leafs under the frame.
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 10-28-2007, 02:35 AM   #3
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
ok...i know i think way to much, but i'v talked to others about this in the past, most think i like to work to much, others just think i'm nuts, but as far as im concerned, if you whant to use s.10 leafs and shacklemount's, no prob, if you whant to use 80's full size truck leafs and so on, no prom, "measue it out and make it work" is what i say....but thats just me ....max.
tiggerstoy is offline   Reply With Quote
Old 10-28-2007, 09:42 AM   #4
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
heck I used one ton dodge springs & mounts under an old ford truck I put together. it just a matter of measuring everything to be sure they will fit & marking where the spring brackets go & bolting it all up. just be sure before u remove the springs from the donor that you measure how far apart the spring brackets are so u get the correct spring ride...joe.
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 10-28-2007, 05:02 PM   #5
Dusty4
Thanks, guys, that's what I was thinking.... I could likely shove most anything under there. I was looking under my 77 Ford, and wondered "why not??" The newer Ford springs look like they would ride a lot nicer than the stock 56 Chevy springs. And the S10 springs sound like a great idea.
Old 10-29-2007, 09:10 AM   #6
solidaxel
solidaxel's Avatar
If you have a Jeep store available to you there hardware fits real good on these chassis, and so do the rear springs!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-01-2007, 10:39 AM   #7
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i thought i read something somewhere about dodge caravan springs, but i have not details or experience there...
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-01-2007, 12:19 PM   #8
55dude
55dude's Avatar
does anyone have the length center to center on the hangers and spring width? that would get you close. it really doesn't matter what you use if your not restoring the truck to stock. guys change jeeps all the time for different uses so why would a old chevy truck be any different. just use some that have service parts available. if you want a decent ride get rid of the leaf springs and use a tringulated 4-bar setup.
55dude is offline   Reply With Quote
Old 11-01-2007, 01:26 PM   #9
1-ton of fun
polishing a turd
stock springs are 2" wide
