Old 10-30-2007, 05:48 PM   #1
kw
kw's Avatar
Water Pump hose--'88 burb
Hey all,
The water pump on my '88 burb finally gave it up.
I have a question about the routing of the hose from the water pume to the radiator.
It seems the smog pump sort of gets in the way, and pinches the hose. There's a piece of foam between the smog pump and hose that I guess is supposed to keep it from chafing. I bought a replacement hose and it's the only way it'll fit.
Has anyone else experienced this? Should I be concerned?
It's a GMC 1988 Suburban with most all the options.
Thanks in advance for any info you can pass along.
Kurt
kw is offline   Reply With Quote
