Old 11-06-2007, 01:28 PM   #1
RustMaster87
RustMaster87's Avatar
Drop spindle help needed, rubbing on upper CA
I put my 3 inch drop spindles on my frame today and the spindle and the lip of the upper control arm are hitting each other. Is there an adjustment I can make or am I going to have to hit it with the grinder? Is this a common thing?
RustMaster87 is offline   Reply With Quote
Old 11-06-2007, 01:32 PM   #2
454HO
Re: Drop spindle help needed, rubbing on upper CA
What brand spindles? I didn't have this problem with BellTech spindles on 2 different trucks. Did you replace the upper ball joints? Sure you got Left and Right correct?
- Greg
454HO is offline   Reply With Quote
Old 11-06-2007, 01:59 PM   #3
RustMaster87
The brand is DJM. I have them on the correct sides. I started off with a frame and have replaced every bushing, ball joint, and soon to be tie rod ends. I hope I do not have the wrong spindles. I have the spindles with the 1.25 rotor, and the correct rotor.
Old 11-06-2007, 02:18 PM   #4
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
what's going on with the steering stop? on some spindles it's cast and some I've seen it's threaded like a bolt into the casting. If threaded you can back it out some. It's a trade-off with spindles that you'll lose some turn radius.
Did you trim the tab for the stop off the LCA? I know a few people who have made that mistake when cutting off the factory bump stop.
as a last resort I've also had to grind the lip most recently with a set of Chassis Tech Spindles on an '84 burb.
Josh
RunninLo is offline   Reply With Quote
Old 11-06-2007, 02:36 PM   #5
RustMaster87
I have not adjusted anything else on the truck as this is as far as I have gotten in putting it back together. When I turn the actual wheel to the front, sending the spindle in towards the motor, I have no clearance issues. I run into a problem when I turn the wheel back into the frame. I just went out and took another look at it and I noticed that the upper control arm bump stop is bottomed out on the cross Member. I wonder if I got the rest of the suspension on it and got if off of jack stands it would allow the upper control arm to articulate up eliminating this clearance issue.
Old 11-06-2007, 08:11 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
What size wheels are you running? If you are running 15x8's then they are definitely going to hit at full lock. It's seems weird that it's the upper control arm. Usually it hit the lower arm. Normally you have to remove the lip back to the shock mount to prevent it from grinding.
If you do remove the lip I suggest you make a boxing plate for the bottom of the arm. I have seen them crack.
You know if you run 17" or bigger wheels it will resolve this issue.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-06-2007, 08:13 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by RustMaster87 View Post
..... I wonder if I got the rest of the suspension on it and got if off of jack stands it would allow the upper control arm to articulate up eliminating this clearance issue.
I just re-read this part of your post. Yes, if you "load" the suspension correctly it will no longer hit the upper control arm. It will "probably" hit the lower control arm if you are running 15x8's.
Articles-
"Refining Sierra"
Old 11-06-2007, 10:09 PM   #8
RustMaster87
The thing that is confusing me is that I do not have any wheels on the truck, and the upper control arm lip is hitting the drop spindle.
Old 11-06-2007, 11:11 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
pics please?
Articles-
"Refining Sierra"
Old 11-07-2007, 07:06 PM   #10
RustMaster87
I took a few pictures so I could show the problem I am having. The only thing I can think of is that maybe the uppers are on the wrong side of the truck? Any other ideas?
Old 11-07-2007, 07:41 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
OK, that's what I thought you meant. You have me stumped there. I have never seen that happen. I have the same spindle on my 77 and have no clearance issues.
Have you considered calling DJM?
Articles-
"Refining Sierra"
Old 11-07-2007, 07:57 PM   #12
RustMaster87
I thought about calling DJM, I will give that a shot as a last resort. If I hit the spindle and the control with the grinder it will fit, it looks like the casting of the spindle has a little too much on it where there is a ridge is on the top.
Old 11-07-2007, 08:08 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
I think I would clean up the edge of the control arm rather than the spindle. It doesn't look like it would take much to clearence the lip.
Articles-
"Refining Sierra"
Old 11-07-2007, 09:39 PM   #14
454HO
Here is what mine look like.
Looking at the 'keyhole' slot and the upper bump stop, it does look like you have the upper control arms swapped.
- Greg
Old 11-07-2007, 09:56 PM   #15
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Yeah you have the upper ca's on the wrong sides
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 11-07-2007, 10:27 PM   #16
f.monroe
f.monroe's Avatar
The small slot in the upper control arm should face the front . It is the slot that the brake hose bracket mounts to . You can see it clearly in 454HO's post . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 11-09-2007, 06:22 PM   #17
RustMaster87
Yea I do have the uppers on the wrong side. I figured there had to be a reason for that clearance issue. Thanks for the help
Old 11-09-2007, 10:33 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Flip them around and report back. I have to know for sure...
Articles-
"Refining Sierra"
