Old 12-19-2007, 06:08 PM   #1
CAMAROSS
CAMAROSS's Avatar
Best place to buy shackles?????
Where is the best place to buy a shackle kit for the rear of my SWB? Also, can you get a 2 1/2" drop or are they only 2" or 4" ? Thanks for the help.
CAMAROSS is offline   Reply With Quote
Old 12-19-2007, 08:08 PM   #2
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Best place to buy shackles?????
There are a lot of vendors who sell them... DJM, Belltech, Early Classic Enterprises, Classic Performance Products...
The shackles themselves only come in 1", 1.5" or 2" drop. There is not enough room under the bed to fit anything more than a 2" drop shackle. If you buy the 4" kit, it will come with spring hangers for the front that replace the factory ones. You will have to remove the existing hanger and bolting the new hanger in its place.
Hope this helps.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-19-2007, 08:15 PM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Keep in mind that even with a 2 inch shackle, you'll more than likely have to notch the bed support underneath for clearance.
xtreme80 is offline   Reply With Quote
Old 12-19-2007, 08:20 PM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I installed some 2" shackles recently on my '94 longbox and had to cut a small notch out of the back of the bed support. It wasn't enough to cause any major damage but when the suspension compressed, there was a light "klunking" noise when the top leaf bottomed out on bed.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 12-21-2007, 10:09 AM   #5
alextreme76
alextreme76's Avatar
are there cheap alternatives to new drop shackles?
like what about shackles from vans? has anyone tried put them on a truck?
'86 Longbed 305
quasi-rat-rod father/son project
alextreme76 is offline   Reply With Quote
Old 12-21-2007, 10:24 AM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Depending on what you consider cheap, they are already inexpensive. A new set of 1-1/2" drop shackles from ECE will cost you $59. The van shackles may work as long as the spring and hanger widths are the same. The only thing about used is the bushings may or may not be in great shape... The new ones come with brand new bushings which is probably worth the few extra bucks.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
