Engine n00b
More n00b questions
what is considered a tune up? plugs/oil/filters/zerks? more? less?
I just picked up this truck, and it runs OK but has some hesitation when cold, and im sure the engine is a little tired. Eventually I plan on having an engine rebuild done (by someone other than myself) What is considered a fair price for that kind of work to be done by a reputable shop? |
Engine n00b
Re: More n00b questions
Oh another few:
- what are popular power steering options? - How could one expect to pay a body/custom shop charge for a gas tank relocation and hiding the fill neck. Before you roll eyes - I have tools, just no garage, so many of these projects are not doable in a dirt driveway ![]() |
Engine n00b
oh, and what size is my stock in cab tank? I cant find that info!
Gone Fishing
ok since you just got the truck I would do this for a tune up
change oil and filter new air filter and fuel filter. Then change plugs/cap/rotor and points and condenser if it is that old points type dizzy. The tank is a 21 gallon I believe.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
yes, i do
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
I am a Referee of life.
Since you mention a hesitation I would also suggest you check the vacuum advance.The diaphram may be cracked and leaking causing the advance not to operate.I had this problem on mine.I replaced the vacuum advance and fixed the hesitation.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#7 | |
Engine n00b
yes, i do
the vacuum advance is on your distributor, near the passenger side valve cover. it should have a vacuum hose attatched to the nipple
