Who has a 9"
I'm thinking of putting one in my shortbed. What are you guys doing to match the chevy five lug with the ford five lug. Is there an axle kit to be had, are you drilling out rotors. I'm trying to decide whether to go with six or five lug disks for the front. If I go with fives then I'll swap rearends. If I stay w/sixes then I'll have to put some time and money in the one I have in order to get posi and the gearing I want.
LAIDOUT
Re: Who has a 9"
I ordered new axles for my 9" because I couldn't find a machine shop locally that would weld up the 5 on 5 1/2" Ford pattern and re drill at 5 on 5.
Re: Who has a 9"
![]() Join Date: Aug 2004
Re: Who has a 9"
If you can find one, the 9" out of mid 70's Continentals and MKV cars have 5x5 bolt pattern, are very close to the stock width, and come with discs. They usually have some family-friendly gears (2.50ish) but are otherwise usable. I just picked one up here locally on CL and there's another one listed now. I have another post with a link to it: http://67-72chevytrucks.com/vboard/s...d.php?t=279624
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 02-22-2008 at 11:56 AM. Reason: add link |
![]() Join Date: Nov 2001
Re: Who has a 9"
Im going with a 9" in my '68 project. my 9" came from a mid 70's Lincoln town car. So, the bolt pattern is 5 on 4-1/2" so weld up and redrilling should be easy machine shop issue. The axle width flange to flange is 64-3/4" so it's right on. I do need to get a different center section as the town car has a factory 3 rib section (junk) so,... I got the housing & axles (axles need redrilled) but redrilling and center section is a easier option for me than narrowing a truck housing.
Going with a limited slip of some sort and 3.55 gears with the stock 28 spline axles.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 02-22-2008 at 12:09 PM. |
Re: Who has a 9"
i have a 9", oh you mean rearends...
Re: Who has a 9"
yeah that questions a little to personal
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
Re: Who has a 9"
Yeah,I wasn`t sure if I was to assume he was talking FlOoReD rear ends until I saw a reply.I gotta big 10".....record of the rythme & blues.
![]() Join Date: Dec 2004
Re: Who has a 9"
I Have A 9" In Mt Derby Car,and I Just Drilled Out The Axles And Drums
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
Re: Who has a 9"
Jacking the thread, but if I am reading correctlly. In order to get a truck 9" to fit, I would have to have it narrowed. I have one out of a 73 Ford F150, I know I would have to get my axles/drums redrilled, but figured the width would be the same.
Does anybody have any info on that part?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Re: Who has a 9"
you can call up strange o rmoser or any of those companies and they will send you the axels you need. just tell them your specs. i got narrowed 40 spline crome moly 5 x 5 axels for my 9in under my 86 swb
