![]() Join Date: Jul 2007
HELP!!!!!!!!!! Is a 68 12 bolt a different width than a 72 12 bolt???
I need to know quickly if a 12 bolt out of a 68 is a different width than a 72 12 bolt???
I am trying to get my chassis done for the car show on the 27th of Fed and I think my axles are too long. Please help thanks for any insight you can shed in advance. |
its all about the +6 inches
Re: HELP!!!!!!!!!! Is a 68 12 bolt a different width than a 72 12 bolt???
the 72 would be about 3/8 inch wider on each side.
The Older Generation
72 is about 3/4" wider on each side I believe..... LockDoc
Well I only missed it by 3/8" on each side... ![]() LockDoc
I have a 68 12 bolt. Since it is not as wide as a 72, does that allow me to run less back spacing for a deeper wheel?
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" ![]() ![]() |
#6 | |
So Longhorn man. In theory if I bought axles, say from superior axle for a 72, the surface that the bearing rides on should be enough and it should all be fine to use the 68 rearend. Right???
Oh I have been meaning to post some picts of a 70 Longhorn that I bought out of Boise but have just been to busy. You will know it when it is up. A beautiful blue with a white top. Thanks again |
"Junkyard Dog"
![]() Join Date: Jan 2008
The 71-72 axle will not work in the 67-70 rear end. Even if the bearing surface was wide enough it would move the brake drum out the difference in the width. As I recall the difference is more like one inch per side.
I am having 5 lug axles made for it, so I have more wheel options. Thanks for the answer.
Rear end for a late 70 on back is 56" and the late 70 thru 72 is 57 1/2" wide. If using the wider axles in the early housing, you also have to use the late 70, 71/72 backing plates, brakes and brake drums. There have been a number of threads on this subject. Try a search for more info.
1997 GMC Sierra Ext 1965 Mustang |
personally, I wouldn't even consider running the wider axles in the narrow brum. But it seems planty have done it and got away with it.
