Old 03-03-2008, 07:22 AM   #1
yellowGT
yellowGT's Avatar
Fuel Pump Question and Issue---need help!!!
Im going to replace my 305 with a 350 unfortunately I cant use a mechanical fuel pump on that block so I bought a Holley Blue Pump. Now, I know how to hook the fuel pump and the regulator but after looking under the truck I found the valve and found out that the tanks have return lines. I will not be using the right side tank so that will be pulled out. Im just going to run the drivers side tank. Just to make sure before I start doing anything..... I am going to run it straight from tank into the fuel pump and bypass the valve, going into the regulator then to the carb and also plugging the return line. Am I correct? Let me know your advise and suggestions
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 03-03-2008, 09:33 AM   #2
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Re: Fuel Pump Question and Issue---need help!!!
I used a Holey Mechanical pump, no return line on it, I just plugged the return line, didn't have any issues with it. Should be fine.
bowtieguy79 is offline   Reply With Quote
Old 03-03-2008, 09:55 AM   #3
us111
hello,,running a 1999 5.7 out of a caddy escalade in my 76,, electric fuel pump, no return line,,run's fine..
us111 is offline   Reply With Quote
Old 03-03-2008, 10:03 AM   #4
bowtieguy79
Ephesians 2:8
Carbed I assume??
Old 03-03-2008, 10:22 AM   #5
us111
hello,,yes,carbed...
Old 03-03-2008, 10:26 AM   #6
bowtieguy79
Ephesians 2:8
sweet, bet it runs good!
Old 03-04-2008, 11:36 AM   #7
yellowGT
yellowGT's Avatar
yes... I know that im not going to use a return line thats why im going to plug it. My question is more towards how to run the fuel line, fuel pump, and bypassing the valve underneath.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 03-05-2008, 12:25 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Why dont you want to run a return line?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
