Old 03-04-2008, 09:36 AM   #1
Kixwy2
Kixwy2's Avatar
Intermittent no start problem
Recently my truck has been giving me issues when I try to turn it over - I turn the key but nothing happens. Zero. Dead. Silent. Since I just dropped a GM crate in it, I also replaced a bunch of the peripherals. Distributor, wires, cap, module, battery cables, starter, etc. I thought it might be a hot start problem, since a couple of them were right after some short trips to the store, but the other day I tried to start it after it sat for a day, and I got nothing on a cold start.
I check all my connections and everything seems solid. I even went under the engine to check for any shorts or cut wires from road junk, but came up with nothing. When I put the negative battery cable back on and tried again, it fired right up like nothing was wrong.
??? I know that cable was tight, too when I pulled it off. Any thoughts or ideas?
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
Old 03-04-2008, 11:06 AM   #2
Vitamin GMC
Vitamin GMC's Avatar
Re: Intermittent no start problem
Hello I recentaly had the same problem, and with the help of this site narrowed it down. Where the battery connection is on the disributer, unplug it. Then run a temperory wire from the distributer to the battery direct. Try starting it then. If it starts, what that told me, it was the ignition switch. Dont leave the wire on when your done, because then its hot all the time. The truck would cut out, then work, then eventually wouldnt start at all. Replaced the switch and works great. Good luck.
84 GMC C10
283 700R4
Cat back w/
flowmaster split
Good Beater
Vitamin GMC is offline   Reply With Quote
Old 03-04-2008, 01:16 PM   #3
89 crew
if it isn't an ignition switch, it has to be a short in the battery cable, bad solenoid, wires going to ignition switch, or wires from ignition switch to activate the starter.
89 crew is offline   Reply With Quote
Old 03-04-2008, 05:08 PM   #4
mhicks
mhicks's Avatar
I would say switch on column. Down under the dash on top of the column.
mhicks is offline   Reply With Quote
Old 03-04-2008, 08:34 PM   #5
wedgemon
wedgemon's Avatar
Switch under lower column or starter solenoid. Most likely.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
