Old 11-23-2007, 12:09 AM   #1
beaterC10
Strange headlight problem
I am having some issues on my 86 that is equipped with dual headlights. When I select low beams they work normally but the high beams are on very dim. When I select high beams, the high beams work normally, but the hi elements in the low beam bulb are on dim. Any ideas?
beaterC10 is offline   Reply With Quote
Old 11-23-2007, 12:39 AM   #2
shadetree
shadetree's Avatar
Re: Strange headlight problem
Poor (loose or rusted) ground.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 11-23-2007, 06:52 AM   #3
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
Agreed or a short in the power wires. I was having a problem with mine, the headlights on - right turn signal inop, high beams on - right turn signal inop and right high beam inop. Some of the wires in the loom behind the grille had been rubbed through and shorted together.
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 03-21-2008, 09:12 AM   #4
hessian18
Gen III Power
hessian18's Avatar
Hello..
Did you ever solve this problem...Im having the same problems you described..
My grounds are all decent....
Next step is to re-wire the lights..
hessian18 is offline   Reply With Quote
