![]() Join Date: Nov 2004
Guage panel and grommet thingy
Any body know if this is the way this cover should fit over the column grommet? I seem to remember that it should ride up higher by where the dashed line is. Why the gap? The holes line up
1972 K-10 SWB Cheyenne |
Cantankerous Geezer
Re: Guage panel and grommet thingy
The rubber goes on top of the bracket.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Out of the carpool lane.
No, it doesn't.
Somethings not right with yours nyncompute. I'd say bend it, but I can't tell if that'll help.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
![]() Join Date: Feb 2004
Did you change out the bezel for that vacuum guage?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
it upside down i think. I just removed all of this for my re-wire hope you figure it out before I have to!! lol Try it
The column looks to be on too steep of an angle you didn't change the bracket under the hood did you.
69 Chevy 4x4 383 Power ![]() |
I changed everything. The bezel, the column,the grommet.. you name it. Was a standard column, now it's a tilt.
Do you have the band on the bracket on the firewall under the hood
More Cowbell....
Hey, your temp needle is missing!!!
Just filler-up with (black) caulk!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Something is up. It looks in your pic that the top of the rubber is squished. The column is too high up in the dash.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
The Older Generation
Column is either too high at the top (my guess) or too low at the bottom. If you have the bracket installed where the column comes through the firewall (engine side) then you may have something put together wrong under the dash..... The cover fits like you have it but the curve should fit up against the curve in the rubber (at least real close) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-02-2008 at 07:22 PM. |
stay on task here mister..one issue at a time! I'll look at the firewall and its mounting tomorrow.. On duty today. Thanks for the thoughts
1972 K-10 SWB Cheyenne Last edited by nyncompute; 04-02-2008 at 07:44 PM. |
Found another!
this seems to be a common problem, you've tightened the column mount under the dash too much.
#15 |
Probably should look more like this -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
