Old 04-22-2008, 04:22 AM   #1
prg machine
prg machine's Avatar
Vaccuum Gage not working
I found this awesome "Motor Minder " gage off E-Bay It looks like it was never used.
I have it hooked up to manifold ( Performer air gap) but i can't get it to read. any suggestions?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 04-22-2008, 04:45 AM   #2
El Jay
Gone to greener pastures
Re: Vaccuum Gage not working
I'm assuming you're running rubber hose directly from the manifold to the gauge.
Make sure you are using vacuum hose. It has a heavier "wall" than rubber tubing, so it won't collapse.
Be sure you have the right sized vacuum hose with a good snug fit over the hose barbs.
Don't laugh: If you don't have some kind of a vacuum pump;get a piece of vacuum hose and run it from the gauge to the driver's seat and suck real hard, just to see if you get any kind of needle deflection. If you do have a pump, sit in the driver's seat and try it
Hope that helps a bit.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-22-2008, 04:53 AM   #3
prg machine
It is the white plastic tubing that you see in the gauge kits. I can feel vaccuum if i unhook the fitting at the gauge and put my finger over it..... but it is a pulsation rather than a steady pull. I have had these lines come loose on other vehicles before and there is an annoying whistle... I unhooked the tubing at the manifold and don't hear a thing. I have a pretty heavy cam lift and duration. also.
383 .040 over
Old 04-22-2008, 02:26 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
If your gauge is OK, you might think about upgrading with copper tubing. It lasts for years.
You might make sure you have no vacuum leaks.
Old 04-22-2008, 03:43 PM   #5
prg machine
I am suspecting the gauge. But I am not sure if i have enough vacuum. I am thinking about hooking it up to another vehicle with a situation that is working now, that way i can rule out the gauge itself.
383 .040 over
Old 04-24-2008, 04:44 AM   #6
prg machine
I feel kinda dumb...................I checked the obvious today, removed the gauge and looked in the opening behind the fitting on the back of gauge. I found a small screw valve in it. I turned it open 90* sucked on it holding it up to a mirror and it works fine!!!!!! I have no idea what the screw is. All I know is i love the fact this cool looking gauge is now working!!!! Timing and what not is off indicating low vacuum and all of the fittings to gauge are just finger tight as well. I was excited and wanted to take a picture so here it is!!!
383 .040 over
Old 04-24-2008, 06:18 AM   #7
ed2552
ed2552's Avatar
looks cool, call up stewart werner, they may have info on how to tune it or w/e
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-24-2008, 06:37 AM   #8
prg machine
Yea! I realy like it. it goes real well with the volt meter to the right of it there. The newest retro from SW called the "Green Line" series. see Summit catalog for them. It is almost a perfect match. Now if i get lotsa extra moneys, I may replace the others with "green Line" but not until the rest of truck is finished. I think the other 2 SW gauges i have are pretty awesome as well. The Oil Pressure gauge is fairly old.
383 .040 over
Old 04-24-2008, 07:02 PM   #9
prg machine
I called the experts. The screw is a restrictor I evidently dislodged some oxidation or minor plugging.
Hope this helps any one in the furure.
383 .040 over
Old 04-24-2008, 07:07 PM   #10
ed2552
ed2552's Avatar
So the volt meter is a new one? wow, they match perfectly, by no mistake, i'm sure
Old 04-24-2008, 11:20 PM   #11
prg machine
Yes. The voltmeter is a "Green-Line" re-issue sold by Summit
383 .040 over
