Old 11-03-2002, 04:01 PM   #1
my new 72
faster, faster, faster
my new 72's Avatar
Turn signal indicator wiring
I put Autometer Gauges in the truck a while back, but I never got around to wiring the indicator light back in. I have a wiring diagram that shows that the light blue wire in the loom is for the left signal, and the dark blue is for the right, but are they on an intermittent ground system. I stripped a small section of wire to test them ,and when I put the ground wire to the light blue wire, and the hot wire to a keyed source the light would light up, and when I turned on the turn signal it would flash. How are these supposed to be wired in? I don't mind them not working, but I would like to get them working because I took the extra time to keep the stock arrow cutouts when I modified the inserts to accept the new gauges.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 11-03-2002, 04:06 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Try running the ground wire, to a ground, and the hot wire directly to the turn signal hot wire. I think that's what I did with mine, when I had the custom cluster in.
Good luck,
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-03-2002, 04:09 PM   #3
my new 72
my new 72's Avatar
I tried that one already and I got nothing. That is what I did first and lead me to ask about the intermittant ground system.
Old 11-03-2002, 04:12 PM   #4
68 Stepside
huh?
Oh, ok. I really don't remember how they're wired now, let me grab my extra cluster, and take a look at the printed circuit, I'll get back to you asap.
TJ
RIP El Jay
Old 11-03-2002, 04:16 PM   #5
my new 72
my new 72's Avatar
Sweet. Thanks for the help.
Old 11-03-2002, 04:23 PM   #6
68 Stepside
huh?
They appear to be grounded, through the printed circuit, to the back of the cluster. If you look in the attached pic, at the circuit, on the far right side, near the top, you can see the little self tapping screw, that screws into the back of the metal cluster, and grounds the circuit.
Hope this helps.
TJ
RIP El Jay
Old 11-03-2002, 07:26 PM   #7
my new 72
my new 72's Avatar
From the printed circuit it looks to be a standard setup with the light blue and dark blue wires being hot, but if that is true, why would the test light come on when I use the blues as grounds, and put power to the other end? And when it is hooked up this way, the light stays on when the turn signal is off, and blinks when it is on. This is a little weird.
Old 11-03-2002, 11:23 PM   #8
my new 72
my new 72's Avatar
ttt
