Old 04-09-2008, 09:22 PM   #1
ddp
ddp's Avatar
WTB - 71 quadrajet carb
I'm looking for a mostly complete quadrajet 4bbl from a 71 350 with the hot air choke components. Don't really care about the CEC/TSC solenoid or bracket. Thanks.
ddp is offline   Reply With Quote
Old 04-11-2008, 05:22 AM   #2
Rust Buster
Rust Buster's Avatar
Re: WTB - 71 quadrajet carb
I may have what you are looking for, but is it specific to the 71? I have a rochester Q-jet with the divorced choke. Is there a number stamping I can check so you know whether it's right or not?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 04-11-2008, 06:14 AM   #3
Green Machine
Green Machine's Avatar
I have a freshly rebuilt Qjet from a 71 C20 350 auto trans. Carb has 92,000 original miles. Has been soaked, new kit, new float (adjusted properly) and new choke pull off and fuel filter. Throttle shafts are tight and also have the choke sping and cover. I have the jet and rod sizes written down somewhere here, but they are stock. I can get the carb number, jet and rod numbers and a pic if you are inteested. I would go $125 shipped. Let me know.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-11-2008, 05:20 PM   #4
ddp
ddp's Avatar
Rust Buster + Green Machine,
Thanks for the responses. I have a 72 carb that I just put a kit in but can't quite dial in and it seems to have some slop in the secondarys throttle shaft. I'm trying to decide if I should repair this one or get another. The truck is a 71 and I've noticed from pictures and parts lists that 71 (and pre) and 72 carbs have a different vacuum brake and maybe other choke linkage parts. Just thinking that if I get another carb, why not match the year.
So, if i could bother you guys? Can you supply the carb numbers?
Rust Buster - the carb number should start with "70" or "170" and should be stamped vertically on the driver's side secondary body section.
Both of you - thanks for your time. Don
Old 04-11-2008, 07:57 PM   #5
rio
Junior Member
oem # 17080212 plus others w/air tube on them,some may be later,will have to rebuild.$50.00 plus shipping.
rio is offline   Reply With Quote
Old 04-11-2008, 09:00 PM   #6
Green Machine
Mine is 7041208 DN with 0741 stamped under that top number.
Old 04-15-2008, 06:33 PM   #7
ddp
ddp's Avatar
Rio - thanks, but that's a later model and I want to go with a correct year carb.
Green Machine - thanks, that carb could work. I'm going to go through my carb one more time over the next couple of weeks. Don't hold it for me. I'll let you know either way after I take one more crack at mine.
Don
Old 04-30-2008, 06:05 PM   #8
ddp
ddp's Avatar
Green Machine - Thanks for the response, your time and offer. I think that I've got my carb squared away and won't be needing a replacement after all. PM sent, as well.
