Old 05-03-2008, 07:18 PM   #1
slugish
Slugish
End Of Rope /please Help
HAVE ANY OF YOU HAD VAPOR LOCK PROBLEMS & IF YOU HAVE , WHAT ARE THE SYMPTOMS & WHAT DID YOU DO ABOUT IT. SOME TIMES MY 400 WONT CRANK AFTER ITS HOT & EVEN HAS A HARD TIME CRANKING AFTER ITS COOLED OFF FOR A WHILE, BUT IT WILL EVENTUALLY CRANK & RUN FINE TILL NEXT TIME & WHEN I GET IT BACK CRANKED IT WILL SOMETIMES BACKFIRE AT CRUISING SPEED.
FOWLED PLUGS ( DO GET GAS & OIL ON THEM ) CHANGE OFTEN BUT LAST TIME WERE NEW PLUGS IN WHEN IT WOULDNT CRANK .
HAVE ALSO REPLACED MSD BOX, COIL &DIST CAP & ROTOR.
LAST GARAGE I HAD IT TOWED TO , THEY COULDNT GET IT TO ACT UP
BASICALLY COULDNT FIGURE OUT WHAT WAS GOING ON .
ANY SUGGESTIONS OUT THERE?
slugish is offline   Reply With Quote
Old 05-03-2008, 07:30 PM   #2
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Re: End Of Rope /please Help
If you have an MSD ignition and you are fouling plugs, you should check the resistance of your plug wires. They should have less than 18ohms resistance, if they are higher replace them.
Also it sounds like your carb is dumping fuel, and your valve seals are shot. Hence the abundance of oil and fuel on the plugs. Could be time for a rebuild on the 400.
Last thing to check, make sure the power wire going to the MSD is a full 12v, if it doesnt have 12v you need to run a wire to the ignition that does.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 05-03-2008, 08:41 PM   #3
454HO
Vapor lock is caused when the fuel inside the lines boils. This can happen on either side of the fuel pump. The fix is to re-route or insulate the fuel lines from engine/exhaust heat.
- Greg
454HO is offline   Reply With Quote
Old 05-03-2008, 10:10 PM   #4
AceX
>130dB Moderator
AceX's Avatar
Check the fuel pump's proximity to the headers as well. My uncle had a buddy who had some trick headers amde for his hot rod but they were way too close to the fuel pump and he vapor locked while going up a hill...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 05-04-2008, 06:21 AM   #5
slugish
Slugish
thanks to all for the responses. Found out after I POSTED that my fuel line runs along the frame rail approx. 1 in from the hedman long tube headers & the header pipes closest to the fuel line are splotchy white (getting hotter than the other cylinders. 1st thing I will try is rerouting fuel lines or just heat wrap them .
