Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-09-2008, 08:16 AM   #1
ocbaud
Garage Queen Material
i need some tires
any suggestions for some GOOD tires that will hookup and are street legal?
the only ones i've seen so far that i'm liking are the M&H drag radials in 275/50/17 (28")
i'm currently running 255/50/17's all around that hook up like crap on the street.
th350 with 2800 stall, 3.73 gears and eaton posi. i know i can get a lot of drag radials if i go down to a 26" tall tire, but thats to low profile for the truck, and i would have to swap out the front
ocbaud is offline   Reply With Quote
Old 05-09-2008, 01:04 PM   #2
71Rat
ran out of money
71Rat's Avatar
Re: i need some tires
im in the same boat as you, i need some dot drag radials also. i had bfg drag radials 275/60/15... they were ok on the street but last night i had it to the track and they sucked!!!
so a TTT for you and dont buy bfg's IMO
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 05-09-2008, 04:43 PM   #3
Couch
Daily Driver
Couch's Avatar
ive heard and experienced good things with MandH but never with a 17''. one thing is that once they start spinning its hard to get it to grab again. its a pretty tempermental tire. but if you wheel it just right they seem to work fairly well. IMO i'd say try em.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 05-09-2008, 08:02 PM   #4
383 Stroker
383 Stroker's Avatar
Mickey Thompson has a 295/40/17 ET Street Radial... It's 27.2" tall.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 05-09-2008, 09:16 PM   #5
70rs/ss
70rs/ss's Avatar
Is two sets of tires out of the question? At 17" you give up sidewall and on a slick (stickey radial) the sidewall needs to give in order to prevent shocking the grip. Run a 275/60/15 at the track and the 17"s the rest of the time, then you can find a 28" tall stickey tire anywhere, heck even a slick if you only use them at the track then the only compromise is the two sets of tires rather than a tire that has to hook and work on the street.
70rs/ss is offline   Reply With Quote
Old 05-10-2008, 06:54 AM   #6
ocbaud
i dont care about working on the street. i've drove it 600 miles since september. it doesnt see bad weather, only nice bright days
Old 05-10-2008, 08:24 PM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
I've heard good things about the M&H drag radial . I also wonder if anyone has any experience with the new Hoosiers . I hear they are super lightweight .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-10-2008, 10:18 PM   #8
PA-IndianRider
PA-IndianRider's Avatar
From what I have heard & also seen on the drag strip I really don't think you can go wrong with either Mickey Thompson, M & H or Hoosiers. All their tires, whether they be street, strip or street/strip are quality products with a LONG history of racing success. So it's really as they say ..... "size matters" and after that application rather than one brand or another. Man, what a difference from "back in the day" .....
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 05-11-2008, 07:39 AM   #9
Outlaw72
Hay Team!!
Outlaw72's Avatar
ET Street Radial fan here....best hard radial I have ever owned hands down.
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 05-12-2008, 12:40 AM   #10
Couch
Daily Driver
Couch's Avatar
agreed
Old 05-13-2008, 11:42 PM   #11
Custom 68
Custom 68's Avatar
well I just put on some Toyo Proxes ST they are a true street tire but so far I am impressed on the street. They are a nice looking tire also. 275-60-15
I will try the track soon.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
Old 05-17-2008, 09:03 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
I have always run M/T and had good luck with them , but this time I ordered a pair of Hoosiers . These will be for the track only as I have to run a drag radial in the class i'm moving to . ET streets are on ebay .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-18-2008, 01:18 AM   #13
chevy72blu
chevy72blu's Avatar
Hoosier qwick time pro DOT's for me. Street legal, but just barely. I have heard they will only last a few hundred miles of street driving... but they sounds like it may not be a concern for them. Mine are 28x14.5 on a 15x10" steel wheel, no inner tubes required.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-22-2008, 03:30 PM   #14
Marv D
Registered Truck Offender
Marv D's Avatar
I've been running Hoosier QT and QT Pro's for about 10 years. The Pro's obviously are softer and don't last as long as the treaded QT, but both have held up well and hooked well for the power I was making at the time. I don't think they make them in the 17" size your looking for, and don't know of anyone who does make a super 'sticky' in that size. You may be doomed to tirespin till you find another set of wheeles you like
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-23-2008, 01:41 AM   #15
straitnate14
straitnate14's Avatar
nitto 555R's kick ass I have them on my 68 and it's got 6psi on a 350 making around 400-420? and I dont think any tire could get any more traction for my setup than what I got now, heat them up just a tad and hang on, they spin for 10-15 feet if your not carful but thats part of the game.
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 05-23-2008, 10:26 AM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
I got the Hoosiers in tonight . tried them out @22 psi and they work good . Dropped them to 15 # Worked even better . Will be on a real well prepped track the 24 th and will report back .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-23-2008, 07:40 PM   #17
chevy72blu
chevy72blu's Avatar
Mine felt real wiggly at 10 PSI. They seemed to like 12 the best. Let us know how you like them!
RIP EastSideLowLife
Old 05-24-2008, 05:52 AM   #18
Couch
Daily Driver
Couch's Avatar
12psi worked awesome for me.i set em at like 10 cold,do some good prep and they worked awesome for me.
Old 05-24-2008, 06:47 AM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
I hope i'm not high jacking this thread , as he would probably be better off with the Nitto's for more of a daily driver . But here's a look at them they had 22#s in the picture . You can see by the dust they needed to come down . I will try 12#s and see how they work .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
