05-26-2008, 09:26 AM | #1 |
Suspension & disc conversion parts list
Hey guys I recently completed the front suspension rebuild. In the process I converted to disc brakes and replaced all suspension parts. I wanted to forward you guys the part numbers just in case it might help someone on the forum. I bought all the parts from the local O’Reilly Auto Parts so you could even order parts online though them. I bought drop spindles and springs through Mike’s Bump and Grind Garage in Webster, TX, he has a website.
Here are the parts and part numbers I used for the conversion: 2 ˝ inch drop McGaughy Spindles 1 inch drop McGaughy Springs New front suspension parts: Pitman arm K6131 39.99 Idler arm K6096 15.99 Ball joint (2) K6024 14.39 each 28.78 pair Ball joint (2) K6023 12.47 each 24.94 pair Tie rod end (2) ES370R 11.51 each 23.02 pair Tie rod end (2) ES350L 11.51 each 23.02 pair Control arm shaft (2) K6098 28.79 each 57.58 pair Control arm shaft (2) K6147 33.59 each 67.18 pair *** I used the low-end house brand, but all of them had grease fittings. I was told by the employee, sometimes the same part numbers of the low-end parts will or will not have the fittings, and might be slightly different in appearance. So, if you choose to go low-end, I would suggest buying from the store not online. Check each part to make sure they match, (Ex: ball joints, tie rod ends) and have the grease fittings.*** I did not buy sleeves from either place. I also returned the outer tie rod ends and went with newer model ones because of the sleeves I ordered from CPP. I did have to drill out the hole on the spindle for the tie rod end.*** Disc Brake conversion parts: Rotor (2) 81-60258 29.39 each 58.78 pair Brake caliper 18-4038 24.69 Brake caliper 18-4037 24.69 Disc pad set EC52 25.11 Wheel seal (2) 8871 1.69 each 3.38 pair Brake hose (2) BH380712 20.10 each 40.20 pair Dust cap (2) 13977 3.59 each 7.18 pair Spindle nut (2) 04993 4.99 each 9.98 pair Bearing (2) A3 7.49 each 14.98 pair Bearing (2) A6 6.91 each 13.82 pair *** verify bearing part numbers before you buy. I remember I had an issue with the inner, but I think it might have just been the kid working there gave me the wrong one but had charged me for the correct one.*** |
05-26-2008, 03:45 PM | #2 |
The Older Generation
Re: Hopefully this will help someone...
Looks like a good investment in safety.... How did you enlarge the tapered hole in the spindle arm? I hope you didn't drill a straight hole in it..... LockDoc
05-26-2008, 08:29 PM | #3 |
coned drill bit.
05-26-2008, 10:10 PM | #4 |
C10 addict
What year truck did you install the parts on? McGaughy sells spindles for 63-70 trucks and the 71-72 trucks. I thought the difference between the two of these was smaller tie rod ends and ball joints for the 63-70 and bigger for the 71-72. Are the newer model parts you bought even bigger than those?
Also, what size rotors did you go with? Are the calipers single or dual piston?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 05-26-2008 at 10:12 PM. |
05-27-2008, 03:01 AM | #5 |
I bought the spindles for 63-70. The tie rod ends I used were 73 newer, I think.
05-27-2008, 04:06 AM | #6 |
C10 addict
What size rotors did you go with? Are the calipers single or dual piston?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
05-27-2008, 05:39 AM | #7 |
I used the stock, 71-72, calipers. They are single piston and the roters are the stock 71-72, 1.25 inch.
05-28-2008, 09:56 PM | #8 |
Will the 71 spindles work on a 68?
05-28-2008, 10:18 PM | #9 |
Project Junkie! Fishing Poor!!
71-72 Spindles will work if you change the ball joints and tie rod ends. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-06-2008, 12:13 PM | #10 |
So to sum it up you used 63-70 style spindles and 71-72 calipers/disks with the prior listed suspension components to make it all work? Are the 71-72 disks 6 lugs? Do you know if there is a 5 lug disk that will fit this application? Thanks!
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1970 Custom/10 LWB-Stock and ugly, for now. 2005 Custom Chopper-100ci Rigid. 2004 Dodge Ram...did he say "Dodge"... |
08-30-2008, 09:58 AM | #11 |
Adding up, everything you bought 503.31. What did you pay for the dropped spindles?
08-30-2008, 10:02 AM | #12 |
I think I paid $200 for them. Mikes Bump and Grind Garage, he's on the site under venders. They're really awesome, prices are great!!!
08-30-2008, 10:17 AM | #13 |
its all about the +6 inches
