Old 06-13-2008, 11:36 PM   #1
randomhero472
randomhero472's Avatar
Removal of front bump-steering stop.. HOW?
Hey guys, another question... how have you guys removed the front bump/steering stop? I read to cut it off w/sawzal and then grind remains which is what i've done, but DAMN its a LOT of grinding... any other ideas???
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-14-2008, 12:13 AM   #2
bedsled71
bedsled71's Avatar
Re: Removal of front bump-steering stop.. HOW?
it only takes like 5 min an arm. put the blade between the two pieces
bedsled71 is offline   Reply With Quote
Old 06-14-2008, 12:31 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Drill out the spot welds...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-14-2008, 07:19 AM   #4
jlaird
jlaird's Avatar
what gringo said. Clean off the lip on the steering/bump stop. You will see a number of spot welds. Center punch the spot weld, drill it out, then take a hammer and chisel to between the arm and bump stop to pry it up. They come off real easy.
jlaird is offline   Reply With Quote
Old 06-14-2008, 08:42 AM   #5
randomhero472
ah, everything was so gunked up i never saw the welds, will do that... thanks guys!
Old 06-14-2008, 09:24 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Just a question,... I understand removing the "bumpstop",... but why remove the steering stop?
Keith
Convert to disc brakes.
Old 06-16-2008, 05:32 PM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
That way your tires will rub on the shocks and frame.....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
