Old 11-06-2002, 03:34 AM   #1
DANL
Will 73-87 GM tow hooks bolt to 72 K5
Will oem 73-87 GM tow hooks bolt to 72 K5?
Thanks in advance.
...Dan
DANL is offline   Reply With Quote
Old 11-07-2002, 01:33 AM   #2
DANL
Has anyone used tow hooks from non-67-72 trucks?
I am looking for something that will bolt up with out mods.
Thanks.
...Dan
Old 11-07-2002, 03:40 PM   #3
MStokes
MStokes's Avatar
I can't answer your question, but here is a photo of a tow hook on my 72 that may help someone else answer your question.
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 11-07-2002, 09:39 PM   #4
DANL
Thanks M.
...Dan
Old 11-09-2002, 01:50 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
The difference between the '73-'80 GM tow hooks and the '81-'87ish is that the earlier ones are much beafier. I've seen the '73-'80 tow hooks on our trucks, but they get too close to the spring perch/spring IMO (there isn't enough room to slip a rope on anymore). I like MStokes' solution, but would add one of those little sheet metal springy clips to keep things from slipping off the hook.
badpeanut is offline   Reply With Quote
