Old 06-23-2008, 12:30 PM   #1
76bonanza
76bonanza's Avatar
lowering question
Is there anyway to measure something in the front to see how much it is lowered now by PO? Wanting to start planning my front end redo and I like the hieght now but am wanting to redo the springs and shocks and stuff.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-23-2008, 12:38 PM   #2
70~BigBlock~Project
70~BigBlock~Project's Avatar
Re: lowering question
I may be wrong but I believe on a 2wd the highest point of the wheel well should be 32" from the ground in the front and 34" in the back for stock ride height. You might want to verify that but LMC's catalog had it as a reference in the 67-72 suspension section.
1970 Custom/10 LWB-Stock and ugly, for now.
2005 Custom Chopper-100ci Rigid.
2004 Dodge Ram...did he say "Dodge"...
70~BigBlock~Project is offline   Reply With Quote
Old 06-23-2008, 01:25 PM   #3
76bonanza
76bonanza's Avatar
of course that would only hold if my tires and rims were the same hieght as stock anyone know the total hieght of stock setup rims and tires?
1968 c10
lowered 3" 4"
Old 06-23-2008, 04:09 PM   #4
70~BigBlock~Project
I believe approximately 28".
Old 06-23-2008, 06:53 PM   #5
76bonanza
76bonanza's Avatar
looks like my tires are 27 inches high. And my front is 291/2 and rear is 30 inches to high spot on arch
1968 c10
lowered 3" 4"
Old 06-23-2008, 10:29 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You will also have to compensate for old saggy springs as well, that will affect the height of teh front end because if you drop in new lowering springs it might actually sit higher than it does currently.
By the way, check out the Midwest part of the board, and see if your schedule is clear for the Midwest All Truck Nats. It looks like we will have quite a few board members attending, and we'll always have room for one more.
If you would like to see different lowering kits on the same truck, check out ECE's (Early Classic Enterprises) stance photos here... this might help to give you a better idea on where you want your truck to end up. Click on the "next" button at the bottom of the page to find the LWB pics.
Good luck with the project!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-24-2008, 09:39 AM   #7
70~BigBlock~Project
If I had to guess your truck is 2 1/2" lower in the front and 4" lower in the back. Do you know if there are any aftermarket parts in the suspension or is it stock components as of now? If its stock then you might plan for a 2.5/4 drop if you like the way it sits now.
Old 06-24-2008, 11:43 AM   #8
76bonanza
76bonanza's Avatar
Nothing in the front. Knowing the PO he cut or heated the front springs but that looks like it. The rear is 4inches only reason I know is he put 4 inch blocks in they will be going soon also. yes I was thinking 2 1/2 or 3 in front and 4 or 5 in rear.
1968 c10
lowered 3" 4"
Old 06-24-2008, 01:18 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
of course that would only hold if my tires and rims were the same hieght as stock ...
True. That measurement won't do you much good unless you have the original tires on the truck. Measure from the center of the wheel to the top of the wheel arch. From past discussions, I think we concluded that the front should measure 19" and the rear should measure 22". This will give you a more accurate measurement of the amount of suspension drop regardless of tire/wheel size.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-24-2008, 01:40 PM   #10
76bonanza
76bonanza's Avatar
that sounds about right slammed I will measure tonight but if I cut my original 27.00 in half and subtract that it is about 3. in front and 5.5 in rear and I always thought it was around 3/5.
1968 c10
lowered 3" 4"
Old 06-24-2008, 02:32 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Take a look at this page.... LINKY
-Nate
Old 06-24-2008, 02:37 PM   #12
SCOTI
SCOTI's Avatar
4" blocks in the rear? Are you certain about this?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-24-2008, 03:16 PM   #13
76bonanza
76bonanza's Avatar
Yup I measured them they are 4 inch my trailing arms are like 2 inches off the ground. The only thing that worries me is the are well below the scrub line so if I get a flat it will suck.
1968 c10
lowered 3" 4"
Old 06-24-2008, 05:12 PM   #14
70c10
67-72 Addict!
70c10's Avatar
Alex, did they stack two sets of 2" blocks or make one thick 4" block???. If I was you I would buy a 5" rear spring if thats what you want and then adjust the front down to whatever rake you are looking for. I like your stance right now!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-24-2008, 05:36 PM   #15
76bonanza
76bonanza's Avatar
Hey jim still love the panels. Yes they are homemade blocks they are completely boxed and look to be very sturdy but they will have to go once I redo the rear suspension.
Yes I was thinking of getting a 5 inch lowering kit with springs, shock relocators ,and adjustable tracking arm. Then seeing how it sits and go from there.
1968 c10
lowered 3" 4"
Old 06-24-2008, 06:17 PM   #16
SCOTI
SCOTI's Avatar
I'll bet they are close to the ground! Definitely downsize to some 2" blocks + the shorter springs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-24-2008, 06:28 PM   #17
76bonanza
76bonanza's Avatar
I think no blocks and 5 inch springs.
1968 c10
lowered 3" 4"
Old 06-24-2008, 06:57 PM   #18
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Okay, so I went out and measured my truck. It's a C10 but has the HD rear spring option (at least it's listed on the build sheet).
I got 20" on all four corner, center of axle/hub to bottom edge of fender. As it sits, the truck is level. I have looked at the ECE stance page and just want to verify, these pictures are what the stance should look like regardless of where I am at now, correct?
Thanks.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-24-2008, 09:46 PM   #19
SCOTI
SCOTI's Avatar
My .02 worth . ..... I feel that lowering blocks actually benefit these trucks w/drops that exceed 4" because they help minimize the amount of shock travel lost w/larger spring only drops.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-24-2008, 10:05 PM   #20
70c10
67-72 Addict!
70c10's Avatar
SCOTI brings up a good point. I'm planning to add a 1" or 1.5" block to the rear of my truck which has 4" springs. I figure with my new KYB's, track bar and a set of relocators I should be good to go. I might even add a thin sway bar later on.
Jim
