![]() Join Date: Apr 2008
WTB chrome steering column
Guys as the title says But I would like a NON-tilt cloumn shifted for automatic one if there is such a thing. but if not a tlit will suffice. Also if anyone knows of a place I could get one that the stock steering wheel fits on or has one for sale. i would love to find one. Must be show quality thanks
~Chris "If your not doing anything then do it quickly!" Last edited by ctucker; 06-30-2008 at 02:35 PM. |
C10 addict
Re: WTB chrome steering column
Are you looking for a factory column or an aftermarket?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
that really dosent matter I am guessing I probably have to have a factory one to get it to accept the factory steering wheel but an aftermarket one will work to
~Chris "If your not doing anything then do it quickly!" |
C10 addict
How much are you looking to spend? I have a factory tilt column that I am rebuilding and was going to have it powder coated, but I could have it chromed instead. If you don't care whether it is tilt or not, it's probably not worth the extra cost to you.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 06-30-2008 at 03:07 PM. |
more details.... are all the internals going to be new? levers going to be chrome to? im interested what are you looking to get out of it? looking to spend depends on quality.
and just a FYI a factory steering wheel will fit on most any after market columns.
yeah but the idiidit and the flaming river which our the only "retro-Fitted" chrome assemblys I have found they say the factory wheel will not mount up. they say you can use an 74-94 OE wheel which is weird to me because I just took that style off and put the original one back on with no mods required although I didnt have the horn button installed never tried it. anyone done this or seen it done with thechrome column with the factory wheel with the horn working?
C10 addict
Yes, I'm replacing all the bearings, levers, seals and the turn signal switch. It will have the factory half moon plug and factory hazard button, not like most rebuilt columns out there. The only thing I don't have for it is the canceling cam, but those are readily available. It probably won't be done for at least a month though so if you want something sooner maybe someone else has one. Chrome plating is $150 alone so I'm looking to get $600 for it.
TILT COLUMN GURU
![]() Join Date: Dec 2006
I can set You up with a factory non tilt chromed from a 69 rebuilt with new turn switch, levers, upper and lower seals for $350 I can post pics of chrome tilts I have sold to see quality of columns later when I get home.
TILT COLUMN GURU
Pics
kevsclassic does your come with the chrome housing for the gear indicator? and all I can say is the stock steering wheel dosent look like it will even do that justice
TILT COLUMN GURU
BlahBlahBlah
Wow, those chrome tilts look very nice...Im sitting down, how much for a chrome tilt?
#15 |
Ohh my..I read 350..Bling ..bling.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#16 |
TILT COLUMN GURU
#17 |
TILT COLUMN GURU
#18 |
all your columns are factory restored correct?
#19 |
"GO DAWGS"
Those are some of the nicest columns that I have seen. I have seen Kev's work and I would not hesitate to buy one from him.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
#20 |
"Trucks with Class"
Here is a new Flaming River chrome & stainless tilt I have ready to go. The arms are really nice compared to others out there.
These are made especially for our trucks, not the generic universal model. $695 shipped ($25 less if you want to wait a month for another to be built). |
#21 |
TILT COLUMN GURU
Yes these are all factory restored columns. If you look at those flaming river columns they do not have the dash seal or fire wall seal. Also upper hub is 1" longer.
#22 |
"Trucks with Class"
The Flaming River is new, not rebuilt and comes with a 2 yr warranty, and it is much better built than the originals.
The upper collar is 1/2" longer than original, but overall length is the same. The custom arms & levers are worth over $100 more than the original/repops, but you do have to spend $20 for the two rubber seals and the column is set up for easy install of the seals without disassembly---a nice touch. Hopefully this additional info will help you decide. |
#23 |
[QUOTE=PICKMUP;2788907]The Flaming River is new, not rebuilt and comes with a 2 yr warranty, and it is much better built than the originals.
QUOTE] in your opinion why is it better than a rebuilt factory column? kev you wouldnt happen to have a picture of one with the stock wheel on it would you? or anyone to that matter. The only thing that is holding me back kev is yours look so good that I am afraid I am going to kill it with the stock wheel....and if thats the case then I am gonna go ahead and get a tilt with a nice aftermarket wheel.
#24 |
67-72 Addict!
Hey Frank, just curious do the flaming rivers come in a floor shift version also?.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#25 |
"Trucks with Class"
ctucker: I can't get the scanned page to show. The FR is designed with new better materials. The difference is on the inside...stainless on the outside is nice too.
c10: Floor shifts are quite a bit cheaper...PM me so we don't sidetrack ctucker's thread. I am trying to just answer his questions & needs on here. |
