Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 07-05-2008, 11:02 PM   #1
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
dual battery question
I want to run dual batteries on my boat, but I need some advice.
How exactly do I connect them?
Right now they are connected to an isolator switch, but it's only charging one battery. I want to eliminate this(I think it's faulty)
Hot to hot, ground to ground?
If I connect 2nd battery to starter and ground, how will it get charged?
A little advice would get you 2 stars in my book.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 07-05-2008, 11:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: dual battery question
Just hook the batterys positive to positive with the same guage cable that the main battery has on it already... and you'll be golden.
Old 07-06-2008, 12:18 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
If I were you I would replace the isolator. In a car/truck application it's not really needed. In a marine application it's nice to have one battery that is isolated for cranking purposes only.
It's kinda hard to get a jump start out on the lake...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-06-2008, 07:39 AM   #4
LONGHAIR
I'm with Ken on this one. If both are connected in parallel, they increase your amperage...which you may or may not need, but they are truly "tied together". They will both charge that way, but they also die together too.
The "isolator" does exactly as the name implies. It uses the same charging source, but the batteries themselves are seperated. You don't get the increased amperage, like would be used to start a Diesel engine or run a winch....but it leaves the "starting" battery alone for starting. Then you have a back-up, if needed, or just a reliable source of power w/o worrying about starting later.
If it was originally wired to run an isolator, I would replace it.
LONGHAIR is offline   Reply With Quote
Old 07-06-2008, 08:23 AM   #5
retodd7711
retodd7711's Avatar
It just keeps getting better
After replacing the isolator(thanks guys, good advice) I still had a no start condition.
Tested both batteries, one is bad.
1000 CCA Deep cycle marine battery.
Can you say cash drain?
She can't cook
So forget her.
My old farm truck
Old 07-06-2008, 10:37 AM   #6
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Check if there's an electric golf cart servicing place around you. They quite often use marine deep cycle batteries for the traction motor and replace them every two years whether they need it or not. You could possibly pick up a darned good battery for pennies on the dollar that way.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 07-06-2008, 11:24 AM   #7
retodd7711
retodd7711's Avatar
One last question.
How do I check if both batteries are charging?
I can borrow a multi-meter, but I'm not 100% what I'm looking for.
She can't cook
So forget her.
My old farm truck
Old 07-06-2008, 03:12 PM   #8
truckdude239
truckdude239's Avatar
check the voltage ont the battery not running then you should see and increase to like 14 volts running
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-06-2008, 03:24 PM   #9
screwballl
Tonawanda 454
screwballl's Avatar
BOAT: device designed to take your money
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 07-06-2008, 07:55 PM   #10
retodd7711
retodd7711's Avatar
2 happiest days in a boat owners life:The day he bought it
and the day he sold it.
She can't cook
So forget her.
My old farm truck
Old 07-06-2008, 11:47 PM   #11
WorkinLonghorn
WorkinLonghorn's Avatar
There's some info here that's pretty interesting;
http://www.tmcowners.com/teamtalk/sh...t=dual+battery
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
