Old 08-17-2008, 10:51 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Power steering ID
I need to ID this pump. It's got a 3/4in shaft with a press on pulley. The one listed for our trucks use a 5/8 shaft w/key (furthest in picture).
The keyed pump and pulley I have won't line up properly, but I think the other will line up when pressed on.
Here are some pictures of the pulleys PN'# if that helps. The first is the one with the 5/8 w/key, the other is the press on 3/4.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-17-2008, 11:51 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Power steering ID
here is a copy/paste by Shane that I found on search.
Shane
Von Dutch Lives!
Re: Power steering pump help?????
there is absolutely NO difference in the pumps between a small block or a big block for our model trucks, the difference is in the brackets ONLY.
early style (late 50's thru mid 60's) pumps had 3/4" in shafts with NO keyway and the pulleys were pressed on.
later (mid 60's up) style pumps had a 1/8" keyway in the pulley ... unsure of shaft size, this was pretty much the standard pump until GM went to the serpentine pulley/belt system ... and some claim the only difference then was the pulley, I can't say.
I have a ZOOP'S press on 3/4" shaft single groove pulley if you are interested, it is polished billet FORGED aluminum , not the Cheap Chinese cast version.
Let me know if you're interested & I can get you a pic or two.
Keep On Truckin'
Shane
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-20-2008, 09:23 PM   #3
Sport/Truck
Sierra Grande Club
bump
Old 08-20-2008, 11:26 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The press on pully pump looks like a 73-up style pump...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
