Old 08-22-2008, 07:46 PM   #1
low900rr
1972 axle swap
Ok so I was at the local pick and pull junkyard today and they have 2 1972 trucks in there both with the rear axles in em. Can I just grab the axle shafts from one and swap them into mine or do I need to grab the whole thing complete.
low900rr is offline   Reply With Quote
Old 08-22-2008, 09:21 PM   #2
fchava
fchava's Avatar
Re: 1972 axle swap
the 72 axle will be wider and different spline, so yes you need the whole thing
fchava is offline   Reply With Quote
Old 08-22-2008, 10:35 PM   #3
SIR
SIR
SIR's Avatar
Re: 1972 axle swap
...grab ALL of it!! front suspention too!! and the rear end will bolt right in all you will have to do is trim 1-1/2" out of the lip of the wheel opening if you have a fleetside..concider yourself lucky most everything that year at most yards is GONE!!! so grab what you can... you won't be sorry!
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 08-25-2008, 06:25 AM   #4
low900rr
Re: 1972 axle swap
we bought both rear axles for $75 a pc. Whats better/different about using the 72 front end parts over the 73-87?
Old 08-25-2008, 12:21 PM   #5
poorboy
poorboy's Avatar
Re: 1972 axle swap
I don't think it's any better but it would be nice to get all your parts off 1 truck.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 08-25-2008, 12:22 PM   #6
poorboy
poorboy's Avatar
Re: 1972 axle swap
Oh and $75 an rearend is a smoking deal.
Old 08-26-2008, 11:17 PM   #7
Captainfab
60-66 Nut
Re: 1972 axle swap
The '71 & '72 ball joints are more expensive and the a-arm shafts have steel bushings like the earlies models. The '73-'87's C10's have rubber bushings on the a-arm shafts, and can be upgraded to urethane bushings if you want.
Other than that they're pretty much the same.
