Resident Curmudgeon
![]() Join Date: Dec 1999
D44 axle question
I have a 70 3/4 ton with a D44 Drum front end. It appears the LH axle shaft has been replaced as the axle stub (outer axle) does not extend thru the hub far enough to put the C clip on it for the stock locking hubs. The RH axle stub is the proper length. There is couple of inches difference in length as far as how much of the axle stubs protrude thru the hubs between the LH and RH sides. It appeared stock on the outside as the locking hubs are the OE 3/4 ton variety used from 70 on. (sorry no pics)
Could someone have put a 1/2 ton D44 axle shaft in there? In other words is the only difference between 1/2 ton and 3/4 ton D44 axles the length of the axle stub? The inner axle and ujoint seems to be proper length. I have a stock D44 axle shaft off a 72 3/4 ton 4x4 (disk brake). Will this axle shaft work on the 70 3/4 drum brake FE, or will I need to start hunting for either: A) The proper axle for a 70 D44 3/4 ton drum FE B) Proper length axle stub Thanks
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all Last edited by CPNE; 08-29-2008 at 10:11 AM. |
![]() Join Date: Mar 2003
Re: D44 axle question
Compare the u-joint sizes side to side. The early 44s had a smaller joint, joints were upgraded in and around 72-73. If the shaft was 'upgraded' it will have the larger joint
Resident Curmudgeon
Thanks. I'm pretty sure the ujoint sizes are the same on both the existing axle shaft and my 72. It is the difference in length between the LH and RH outer axle stubs that has me perplexed. Just wondering what I may have.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
The only thing I can think of is the drum brake factor. Maybe there is a difference there? Maybe the PO used a disc brake style outer axle? (if they are different)
1/2 and 3/4 ton are the same as far as the axle itself, in the disc brake version, but again I am not familiar with the drum type. |
#5 | |
1/2 to 3/4 ton is no difference, that I remember. |
outer is the same on corp 10 as well, inner is different length
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Have you had this truck or is it new to you?Do you know if the 4wd was working?Was it together and you took it apart,then discovered it there was no c-clip or was it apart further?Like,was the spindle off and it`s going back together?
I ask because I`ve found these assembled wrong in a couple ways and I couldn`t get the c-clip on the stub.I`ve seen two bronze spacers behind the spindle bearing seal/on the base of the outer axle for some reason.I`ve seen the same spacer between the the spindle nut and the lock-out.
Resident Curmudgeon
Here is what I found. It was assembled with the correct parts, just driveshaft stub too short. As you can see, it had the larger diameter axle and bigger ujoints. FYI, the 72 axle shaft slid right in and everythiong assembled perfectly.
